Mike, have you ever had those ramps move forward when the tire started to contact the ramp?RhinoRamps.
Amazon.com: RhinoGear 11912ABMI RhinoRamps MAX Vehicle Ramp - Pair (16,000lb. GVW Capacity) : Home & Kitchen
Buy RhinoGear 11912ABMI RhinoRamps MAX Vehicle Ramp - Pair (16,000lb. GVW Capacity): Table & Chair Sets - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
I upgraded to those Rhino ramps a year or two ago, as my old ones were of questionable capacity. The approach angle is pretty low, and they don’t slide at all on my smooth concrete floor. However, to be safe, I put the truck in 4HI when using them. I think you’d be fine if you just keep the rubber “grips” clean on the bottom.Mike, have you ever had those ramps move forward when the tire started to contact the ramp?
I have a pair of Rhino ramps very similar in design that slide easily on my driveway surface. I noticed the pattern is different on the one's at Amazon compared to mine and was thinking they might have made a change.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 053727 miles.
Speedy's reply is spot-on. My garage floor is polished concrete, so even rubber can slide on it. Putting the truck in 4HI keeps that from happening. I also wedge them in as far as I can when placing them. If my floor had any kind of texture at all they wouldn't slide because of the rubber "grips" built into the ramps.Mike, have you ever had those ramps move forward when the tire started to contact the ramp?
Best regards,
Dusty
Mine move all the time when you start to contact the ramp. What I do these days is just jack the vehicle up and slide the ramp under the wheel, then lower the jack. It's simpler than the ramp kicking out or (worse) driving off the ramp by not stopping fast enough. Mine are the "Rhino" ramps with the rubber underneath, but over time the nubs wear and it won't hold on a smooth concrete garage floor any more.Mike, have you ever had those ramps move forward when the tire started to contact the ramp?
Best regards,
Dusty
I use these as well. Work great on all the surfaces at my house: pavement, dirt, and gravel.RhinoRamps.
Those are a great idea, but I won't pay $160 each for them. I might just steal their design and build my own for my use.Has anyone used these? Not cheap but seems like an easier solution.
Product No Longer Available
We're sorry, but we no longer manufacture this product. Please take a look at some of our other great products! "The perfect tool for a tough job" -Russell "Top notch quality and customer support" -Brad "Could save your life" -Romeosafejacks.com
