2022 big horn 5.7L. Looking for the best muffler swap without removing anything else. Want it to be twice as loud and deep without the rasp. Was thinking either Borla S type or Flowmaster 44. Thoughts or advice on what you did?
If you want loud get the Atak and not S type.2022 big horn 5.7L. Looking for the best muffler swap without removing anything else. Want it to be twice as loud and deep without the rasp. Was thinking either Borla S type or Flowmaster 44. Thoughts or advice on what you did?
Isn't that a cat back system, I only want a muffler. In the borla site I could not locate a borla Atak muffler. It's a lease, so I need to mod to a point where it will be easy swapping back.If you want loud get the Atak and not S type.
It appears the b2 is more than just a muffler, it wants to delete the resonators. I only want a muffler.B2 fabrication offers the cheapest options, but no way you get out under 200.
230 and up...
Premium Aftermarket Exhaust Systems for cars & Trucks
Explore high-performance aftermarket exhaust systems from B2 Fabrication. USA made, our systems are designed for trucks like the Ram 1500 and Ford F-150, for enhanced sound, power, and durability. Get the perfect exhaust fit for your truck with easy bolt-on installation and unmatched performance.www.b2fabrication.com
Do you have a sound clip by chance? Is it super loud? I have a 1972 Pontiac Lemans with Spintech 9000 mufflers that are super loud which is fine, but this is my everyday car so it can't be blaring loud. A nice deep growl, no rasp is what I'm after. So far the one clip I seen sounds raspy/poppy with the outlaw and all resonators on.Flowmaster Outlaw, 60s era muscle car sound, similar to a full ATAK Borla system, just not quite a refined. About $270 muffler and labor installed at my local muffler shop.
As with all muffler only systems. you will get a bit of drone when in MDS 4-cylinder mode. Most turn off MDS (for many reasons) to prevent this, while I personally got used to it. Otherwise, no drone when cruising or on the highway at steady throttle in full V8 mode.
No thats not the right one, dont know how it compares to a super 44 ive never heard one of those. I'd recoment looking on a truck website for the proper Fx mufflerFor the Flowmaster fx, is it 3" in center and 3" outlet offset? This one? How does it compare to the super 44
https://a.co/d/aXhAZFy
