Bell tech 0-3” adjustable strut
Kwalker88
Just installed this with sky jacker UCA, set on 2” setting called bell tech to confirm needed rings. Put everything back together and had a total of 3” of level I had one black 15mm spacer and 1 silver 16mm spacer left for each side. Not sure how this happened anyone else have this problem, will be aligning tomorrow.
before fender height 295/70/18
front 37 3/4
Rear 39 1/2
After
Front 40 1/2
Rear 39 3/4
Now it has 3/4 of rake. Don’t under stand it. Will be returning 295s for 35x12.50x18 and leveling rear 1” now..
Does your truck have the Offroad Package? If so the Offroad Package springs will give you a extra 1 inch of lift.
No off-road package, I drove the truck 10 miles it settled back down and is now reading dead level! More than satisfied the truck drives and responds great better than stock. Still needing alignment tomorrow will post pics
295/70/18 18x9 slight rub on mud flap, if she still runs after alignment might swap out for 285/75/18
Also wondering if putting a little rake back in the rear would eliminate this rub (3/4-1”) because I had these wheels and tires stock and they cleared fine (close)
