Bed Step for Single Exhaust
TennVol
San Juan de Dios, Anton, Cocle, Republic of Panama
I have searched the threads & I have found a lot of info on bed steps for dual exhaust vehicles, but nothing on single exhaust vehicles.. I have a 2023 1500 Bighorn with the 3.6L eTorque with a single exhaust. Can anyone help with a link? Thanks!
What does the exhaust have to do with the step placement?
It doesn't mount to the exhaust.
Is there is only 1 side step and bed step. Side step is for normal trucks, bed step is the middle mounted one intended for trucks with MFT. They install at the same mounting area so you can't use both.
I know it doesn't mount to the exhaust - I had one on my 2018 Power Wagon. Every one I've seen indicates they are only suitable for a dual exhaust truck. I've yet to find one that is either only for a single exhaust, or is suitable for either. I can't imagine the mounting point would be different regardless of number of exhaust pipes.
Again, I don't know what else to tell you.
Has nothing to do with your exhaust.
Only lower trim 1500s get a single exhaust pipe but it's the same engine anyways.
The Eco diesel had single exhaust as well.
If you're only talking about the number of pipes sticking out under the bumper, my 2021 Eco has dual exhaust.
Must be a higher trim level thing. I know the Bighorn was only single exhaust behind the tire.
Have you found the bed step, cause I have a 2025 with the same problem?
look at the pdf darksteel posted above
get under the truck and see if you have the holes in the frame.
if so problem solved
cause as far as I know the frame is still the same on all DT trucks, except maybe the trx and rno
I installed a tailgate ladder, because I’m not going to pay the crazy prices for the folding step. This has definitely made it easier on my knees.
I’m really interested in this kind of setup. I’m curious how it performs on uneven ground or even on an incline. Are there any issues with the ladder feet touching the ground in those scenarios?
I have not experienced any problems with the stability of the steps on uneven ground. They are double hinged near the tailgate that allows the steps to deploy on higher and lower than grade terrain. I got them on Amazon (Beech Lane Pickup Truck Tailgate Ladder $63).
