Bed Rack With Ram Boxes
TRUKD
Hey all! Joe here from TRUKD. We just installed our A Series bed rack system on a 2500 Ram with Ram Boxes. I know there aren't many options out there for bed racks that work with the Ram Boxes, so I wanted to share this and hear your thoughts. Let me know what you think! This isn't on our website, but let me know if you're interested in hearing more.
Looks nice. How easy is it to remove the rack system if need to do that temporarily?
It's super easy to remove! Each of those uprights is held in place with 3 bolts to the lower mounting plate. You have 12 bolts total to remove and could lift the whole rack off in one piece. They're easy to access as well. You can keep the lower bracket in place, which is sandwiched between the utility rail and bed.
When will it be viewable on your website, with specifications like material, weight, etc.?
We're working on a landing page for this now. Weight will depend on the height you choose. Our tallest and heaviest rack weighs around 100lbs. Our racks are a mix of 304 stainless steel and aluminium.
Nice design for the 6.5’ bed. Not for me, but maybe others, how would this fit on the 5.7’ Rambox bed? Obviously (or not) since the rack is one piece, it may not fit the shorter box.
Maybe the rack could be fabricated to fit either length bed. Just an idea.
Since it looks like the bed rails are spaced inward some, it may create a clearance issue with certain bed covers. I have a Retrax rolling cover that I wonder how the width between the rails would affect it.
I'm in the same boat you are, my 2020 half-ton has 5' 7" bed.
I wish Ram had come up with the idea Ford recently patented:
Ford Patents Built-In Pickup Bed Rack With Stowaway Rails and It Sure Seems Handy
