Bed Rack for Roof Top Tent
2019ramrebel12
Mount Hope, KS
Finished and installed my custom bed rack. I wanted something that would allow me to put a Smittybilt overland xl (weight capacity of 700) on top but still allow use of the rambox and my bakflip bed cover. Not perfect but for about $200 in materials and a couple days work, I'm pleased. It's about 1 inch taller than the cab height, still shorter than the antenna and should hold the family and then some!
This as an easily on/off thing would be awesome!
Great for our canoe/paddle boards. And tons of room for everything else when we go camping !
I suspect this is something you can sell. Would love to see how it is mounted to the bed. Fantastic work!
I popped the corner plastic pieces off the top of the bed sides and bolted it to steel pieces below that function to sandwich the factory steel between it. It takes about 2 hours to take off or on, but that includes removing the ramboxes. I tried to mimic the nuthouse industries design, but taller to allow me to use my bed cover.
I'm going to pretty much copy yours for my RTT. What size and guage of tubing did you use? I was thinking 1.25", 14 ga.
I used 2" tubing with 1/8" walls. Total overkill but I figured I would rather have it too stout than not support whatever weight might end up on top.
Dealer sent over this picture after the detail. Should be delivered tomorrow AM. $41,600, and all said and done, taxes, fees, shipping to my door (200 miles away) were at 44K. Apart from the $600 doc fee, I'm not upset. 2019 with 14K miles. Luxury package, Uconnect 12, pano sun roof, level 2 equipment group, bedliner, bed step, side steps.
Question: I have always bought factory extended warranties. The dealer is pushing for Assurant. I was planning to just get the one from Ziegler everyone talks about here. Thoughts?
Built up my own rambox compatible rack and happy with how it came out. Thanks 2019ramrebel12 for the inspiration. The rack mounts with no mod's to my truck and works with both the rambox's and backflip cover. Now just need to put the RTT on it.View attachment 58568View attachment 58569View attachment 58570
Nice work. I'm taking the family out next week for a couple camping outings to get some use out of my rtt for the first time. Throw another picture or two up after you get a tent.
Will do. We're going camping Father's Day weekend (already have a tent). Should be interesting, it's the first time I've convinced the wife to join me in the RTT.
I'm installing my RTT this week to Yakima OutPost HD / HD Bar system which will sit over my retraxone XR cover and have a couple of questions you might be able to help me with? 1. When you are camping and have the RTT deployed, do you do anything with the air suspension? Put it in Jack/tire mode? ... I really wish you could manually control each corner of the air suspension, would love to be able to use that to help level the bed/tent. 2. I've been trying and failing to see what weight the bed / side rails can safely hold. I'm assuming its more than the Yakima HD bars and my RTT can, but I'd love to see it in a manual somewhere. Any idea or where to look?
Going to make a video of the whole install process and my RTT tent specifically as I struggled for a long time on what to buy / how to make the set up because I couldn't find a lot of good information out there. I'll post that here when its done too.
1. I just put the suspension in entry/exit, to lower as much as possible. 2. I don't know where to look for the weight rating of the bed rails and I doubt you'll find it as it would be dependent on distribution of the weight. It's pretty safe to assume the bed side can handle more than the Yakima system.
First time out with the family to camp. Trip went great other than a bit of damage getting to our spot. The trail (Metberry Gulch, Colorado) was much tougher than expected and ended up scraping and bending the mess out of my steps, losing a fender flare, and breaking an exhaust hanger. Got most everything patched back up when we got home. Glad I have skid plates and am eagerly awaiting the arrival of my White Knuckle sliders that will go on before our next outing.
That's pretty slick. I went the complete other route and built a separate trailer for my RTT so I could drive away after I set up camp. I installed it to a 1000 lbs lift cart chassis that I removed the casters from so I could scissor lift it with the hydraulic pump up to height and be able to walk under it. It lowers down to below the truck level for a bit more efficiency while driving. I love seeing people's solutions for camping.
You can see it here collapsed and ready to go and then a good shot of the general design while I was building it. It's a much cleaner finish. Like those Rambox racks, though! I'm trying to figure out what over-bed rack solution I want to use for my bike racks.
That looks wicked, are you going to add mounting points for traction mats and may be jerry cans?
