dailyherold
Got a pretty great used deal off Amazon for the full liner on my 2019. Don't think the previous owner did any modifications, but two things that were kind of odd for my fitting:
- The passenger sidewall is noticeably shorter than the driver side. Enough that I'm wondering if the previous owner did cut down the height. Driver side tucks way under the black rail, whereas the passenger side doesn't reach it. I thought maybe the rails were adjusted differently, and still have to play with that, but can't imagine that far off because rails should be pretty parallel for good tonneau cover fit? Difference could have been my install method of sidewalls, but I did the same thing and really tried to jam the zippered edges in the corner of flat and sidewall so things would be nice and tight.
- The tailgate cover seems shorter on mine than others. Upon first install I didn't have the J channel and after install realized I wouldn't have a good flat surface so called them for the channel which was shipped out promptly. Added it, but channel doesn't extent far enough for me to have any overlap with velcro if I put it on. So instead I just tucked the finished edge under J channel lip and used some of the velcro in kit to keep the corners down. Works pretty well actually but odd mine seems much shorter. I was initially going to try and really pull it towards tailgate because I noticed it on dry fit, but decided I'd rather get the ribs of sidewall in line than be half a rib off the whole way just to get it to tailgate edge.
