Didn't get the bed utility group with my truck. The holes everywhere aren't going to be fun with gravel or winter driving. Anyone have a solution to plug these? I have Rhino lining already.
If you have the rear wheel liners you shouldn't get much thrown up there. What you could do to fill the holes is add the rivet nut inserts used to hold the bolts that attach the BUG rail and then screw in a nice looking round head bolt in black or stainless. You could also then remove the bolts and add ring head bolts to attach stuff.
Every time I trade in a truck that I drilled through the frame to mount a plow, I plug the frame holes with plastic push pins to avoid getting dinged on the trade in value. Usually can't tell they even had a plow mounted on them. Amazon has them in all different sizes, they would blend with your bedliner and if you really want to make sure the holes are waterproof, put a small bead of some black rtv sealant under the push pin head before you push it in. The head will blend with the bedliner and the sealant will fill any imperfections so you get a good waterproof seal.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
