BATTLE: 2019 Ram 1500 Laramie Sport VS Laramie Black:
redriderbob
Co-Editor & Ram Guru!
Metro Detroit
5.7-liter HEMI V8 vs 5.7-liter HEMI V8 With eTorque...
Cortesio
Iowa
I see you're enjoying your early November snow as much as I am :ROFLMAO:
I'm excited to see the content you guys put out about your long term truck. Mine came pretty similarly equipped so I'll be following this and the rest of your long term content closely. Keep up the good work (y)
StuartV
Lexington, SC
Please, please, please do a test to compare fuel economy between the 2 when being driven on cruise control at a steady 80 MPH!! My truck is virtually identical to your new tester. I am turning around 2200 RPMs when I'm rolling on the Interstate and I think it's the 3.92 gears that make it spin that high and suck down the gas so quickly.
Also, please do NOT rely on the onboard computer for your mileage reports. Some people claim that their onboard computer is accurate. But, I have tracked my mileage at every single fill-up (for 8K miles now) with Fuelly. The onboard computer is occasionally spot on. But, it is often off by anywhere from 1 to 2 MPG. You won't know if yours is accurate or not unless you hand calculate over a number of fill-ups...
Lastly, be aware that using Adaptive Cruise, vs regular Cruise Control, seems to cost me over 1 MPG in fuel economy (because of the way it slows down and speeds up whenever I start to get close to a car in front). So, if you compare fuel economy with these trucks, please use regular Cruise Control for both, to keep it apples to apples.
Diamondback
Midwest
It would be your 3.92s .. I'm around 1500-1700 at 70 mph in my 3.21 with 20" tires
To make it a fair BATTLE (which I didn't see any battling in the video myself, just the pre-Introductions) ..
5.7 Hemi 3.21 vs 5.7 Hemi eTorque 3.21
or 5.7 Hemi 3.92 vs 5.7 Hemi eTorque 3.92
That way, it is still Golden Apple vs Golden Apple and Red Delicious Apple vs Red Delicious Apple ..
or a mix-and-match of each I suppose depending on if you are comparing the axle ratios with your battle, or the engines.
StuartV
Lexington, SC
I am less concerned with seeing how much difference eTorque makes and more interested in what difference the gearing makes - and at the speeds I normally drive on the Interstate (which I think are not that unusual - 80 MPH in a 70).
I know that my gearing is making a difference in fuel economy. I would just like a solid idea of how MUCH difference.
TWRam
How do you know the computer isn't correct and the sensitivity of different fuel dispenser shutoffs is making your hand calculation incorrect??
When I top off the tank, I can usually add over another gallon to the tank after the initial automatic stop of the pump. Some pumps will let you add a lot more than others. This translates to up to around a 5% difference in fuel added which calculates out to around a full 1 MPG variation depending on where the pump stops your fill. With that in mind, the accuracy of a "hand calculation" of any given tank can be off by a full MPG. It is no wonder that the numbers do not align with the computer, but occasionally do. It is the average hand calculation of many fill ups that will show the accurate number. Unfortunately, when you compare the average of many hand calcs to the computer, they STILL won't line up because I believe the computer averages the MPG over a rolling 300 mile span....which is roughly 1 tank. With that said, it seems that it may be impossible to accurately compare hand calculated MPG to the average MPG as shown by the cluster. Lame eh?
So now that we know hand calcs can be very inaccurate, how do we make accurate comparisons? Back to the computer! Given that we are comparing 2 identical trucks with only one different variable, the strategy for calculating MPG in the computer will be the same in both trucks making the readings 100% relative and accurate for identifying the MPG variation based on whatever the singular or hand full of variables may be.
StuartV
Lexington, SC
First, I mostly fill up at the same station. Maybe that matters. Maybe it doesn't. I do not use the same exact pump every time.
Second, I fill until it clicks off, wait 5 - 10 seconds, then pump again at about half "speed" until it clicks off again. It generally only accepts another 0.2 gallons or so. The way I see it, it doesn't matter what the initial cutoff is. If you keep putting gas in until it is clicking off immediately, then I reckon it is full - to the same approximate level every time.
Third, I generally run the tank to near-empty, so I'm putting in more than 25 gallons at a time. The volume and number of miles involved serve to reduce the margin of error. When I talk about how "off" the onboard computer is, I don't even consider the differences between onboard and hand-calculated for fill-ups where I put in 10 gallons or less. The margin of error on those is too high to bother considering.
Also, I reset the tripmeter and the Fuel Economy screen every time I fill up. Unless the way FE is calculated is totally retarded, that SHOULD mean the FE screen and my hand calculation on an individual tank should always match (within the limits of accuracy of the way I fill the tank).
Everything you said still doesn't account for differences of 2 MPG between the computer and hand calculation (again, over fill-ups from a near-empty tank).
If the difference in numbers was because of big differences in the actual fuel level I achieve on each fill-up, then the numbers should be distributed pretty evenly between the computer being optimistic (i.e. reading high) and pessimistic (reading low). But, they are not. The computer almost always says I got better mileage than I really did.
My overall average (of 14.4MPG or so) is the total number of gallons I have put in over all time divided by the total number of miles I have driven. So, the margin of error for that calculation is VERY small (presuming the odometer is accurate, of course).
The bottom line: Hand calculating is pretty darn accurate when you do two things: Limit your observations to fill-ups from near-empty, and consider the data over a number of fill-ups. And, unless they have been doing a reliable, reproducible hand calculation every time and comparing that to the onboard (which gets reset every time), anyone claiming that the onboard computer is reliable and accurate is really just spouting wishful thinking. Maybe theirs is. Maybe it isn't. But, if they haven't checked it a bunch of times, over a bunch of miles, there is no way to know whether it is or not.
