Battery Change??
Billabq
I need to replace the battery on our 21 Rebel. Are there any kind of computer or other resets needed?
Not really you might get a check engine light after you change the battery because of the different in voltage register by the BMS. You can use a regular OBII reader and clear any faults.
This is a good video that walks you through the process
