John89
- Mar 2, 2021
Yeah it’s weird. So, I just ended up reversing all the pins on the metra 72-6514 adapters that way I would keep the polarity the same (-) (effectively converting them to the 72-6515 adapters)on all my speakers. I then removed my ANC bypass to see if the drone noise was somehow being caused by the reversed polarity, and now there is no drone noise being produced by the ANC via the speakers! Crutchfield is the source of truth, the metra 72-6515 are the correct ones in order to keep the polarity the same.
if anyone swapped their factory speakers I highly recommend you check the polarity on them and make sure you leave it the same as they were from the factory. When you switch it up, it seems to mess with the ANC and you’d be forced to bypass it.
TLDR;
Crutchfield is the source of truth, the metra 72-6515 are the correct ones in order to keep the factory polarity the same and be able to keep your ANC system active if all you’re doing is just swapping the factory speakers and not adding a aftermarket amp.
TLDR;
