Bank 2 VVT Solenoid gasket leak
Iridium
Decided to check the truck for any leaks and found that the VVT solenoid gasket was leaking. easy fix btw id say 30 min. including cleaning of the plastics lol
I won't go into full detail due to how easy it was to remove/replace. you'll just need the following:
10mm long socket
8mm long socket
6 inch extension 3/8 drive
flat head screwdriver
clip pry driver thingy (idk what its called but i use it to remove any plastics).
Part #4893803AA (Local dealer had it for $15 out the door)
Cleaned the area around the solenoid with brake cleaner as much as i could*
Hope this helps anyone.
