Sorry it took so long for this reply. If I had it to do over I would get the "Revolver". It cost more but after seeing it on a friends truck and how simple it was to open and close I wished I had gotten that instead.
Maybe this wouldn't be an issue for you, but, I'm 78 years old and lifting the BackFlip and be very difficult for me. Plus, when open all the way, the rear window is completely blocked. When the revolver is all the way opened the rear window is clear. Just my 2 cents.
I have the MX4 and the cargo management with no interference between the two during install or operation. When fully up, rearview mirror is useless. Luckily, I have the digital rearview mirror which I flick on in these situations. Its camera is not obstructed by the raised MX4. Not sure about other Bakflip models.
So I wouldn't get the MX4 without having the digital rearview mirror. And yes, you need to brace a little to flip up the last stacked section. I can imagine some people with hand dexterity issues needing to go into the bed for this purpose... if they have the bed step and good knees.
I have the MX4 and the Limited with the digital rearview mirror. Only reason I got the MX4 this time was because of the digital mirror. If I did not have that, it would be the revolver all day.. Had that one on my last 2 or 3 trucks
It was packaged with the Longhorn Level 1 Equipment Group (HUD, Adaptive cruise, Digital Rearview, Blind spot, Power running boards, updated audio, Surround view cameras, Sprayed bed, Wireless charging). Can be had in other trims with various packagings.
Basically, it displays a live image on the rearview mirror from a rear facing camera located externally at the back end of the cabin near the top. A button on the mirror housing allows you to switch between the display and a regular reflective mirror view.
Superfluous for the most part and not worth a retrofit, in my opinion, unless one is bent on getting a tri-fold bed cover or install a bed rack that would obstruct rearview but not high enough to obstruct the camera.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
