Yes, I have had the black screen very intermittently, and it seems to occur when parked outside in colder temperatures.
One item to check is the tailgate harness connector below and at the center of the tailgate, on the truck.
Leaving the gate closed, and release the locking tab on the RH side of the plastic cover.
Crawl underneath and release the two christmas tree wire harness mounts closest to the tailgate connectors.
Then pull the cover and connectors out from underneath the gate, they can now be unlocked from the cover, disconnected, and inspected.
Keep the connector ends clean, don't allow dirt to enter.
Any corrosion of the pins may require repair or replacement. Note: The camera video is a coaxial cable. The multi wire cable is for the pin switches and the gate release solenoid.
If ok, reassemble in reverse order, making sure that the locks in the connectors fully lock upon reassembly.
