gcscott
If you don't have the back-seat release (non reclining seats), the back seats can be modified to lay down with a simple cut to the seat back retainer clip. I did this mod on my 2013 Outdoorsman when I installed an amplifier behind the passenger back seat. First you have to remove the seat bolts, only do one seat at a time. You need a 3/8" socket and an 18 mm. socket. Lift the bottom seat all the way up and remove the front e torx bolts using a 3/8" socket and don't strip the edges, then using the 18 mm. socket remove the back bolts. The bolts will be very hard to remove at first and then will become easier. With the bolts removed, place the seat bottom at a 45-degree angle, lift the whole seat up until the back of the seat folds forward. Now with the back folded forward, reinstall the mounting bolts that you removed earlier. On the back of each seat is mounting clips that need to be cut. Measure the white clip 1-1/2" from the end and put a mark where you are going to make the cut. Use a hacksaw to cut the clips and don't cut off the entire clip, only 1-1/2". You will be cutting the clip which is made with metal and plastic and be careful that you don't cut the seat fiber backing. After you cut the clips, raze the seat back all the way to the rear upright position and hold in place. Place the bottom seat at a 45-degree angle, lower the seat to normal position and the seat back will lock in place. Now discard the cut off clip ends and do the other seat the same way and you are done. When you raze the seat bottom to a 45 degree position the back part of the seat will rise and will release from the mounting hooks on the back wall of the cab and will now fold down. Enjoy.
