So, what'ya gonna do?
I don't see what it would hurt to still run the Bilsteins that it came with. It will give you an extra inch in the front and all your angles should still be well within the proper specs.
Also, I didn't realize the kit used a small preload spacer in the front as well. It looks like it is only good for an inch. If you end up leaving it at its current height, you could use the stock Bilsteins and do away with the preload spacer for a slightly better ride.
Looks good! What did you end up having to do?Much, much, much better
Thats insane. What struts were you using originally? Struts from another 2019? Or struts from a 4th gen? I know 4th gen struts are not as long as the 2019s and is why nobody is leveling with Bilsteins yet.Rebel front strut, no pre load spacer. No BS, got 1 1/4" more clearance up front.
