I can't seem to clear it with Alfa obd. I'm not sure the restraint system works the same wayI’d clear it and see if it comes back
The dash was pulled out slightly to look at the HVAC and a pillar for possible air leaks. Disconnected the passenger side floor board wires but they are all reconnected now. No idea?Question: what work was done that required disconnecting the battery? Could something have been left unplugged? Could a wire have been pinched somewhere?
Aside from that, a huge number of problems that occur after disconnecting the battery cure themselves if you give it a day.
