B.U.G., bed utility group, bed rail accessories?
TNRamGuy
Knoxville, TN
does anyone have a part or aftermarket for crossrails, accessories. 4 tie-down point seem like a waste
I have been on the forum for 2 years and to my knowledge there is no after market. There is a post where someone made there own from railing used to hang electrical equipment. Below is a post with T nuts that will fit the rail, but did not go further to explain how they were to be used.
Thanks for the reply
I have made a few things using the uni strut nuts. You can get a couple different size and then the possibilities are endless.
I use a set to mount a bike rack at the back of the bed. Takes about 20 seconds to install and remove.
Photos?
This is very helpful. So the rail is $218 and the divider is $252. Bed Utility Group is definitely worth the price then
My truck came with the Bed Utility Group but it did not include the divider.
I ordered my Ram in Sept of 2018, from what I can remember the BUG was $650 (give or take $$) and included 1. bed lights, 2. spray in liner and the 3. bed rails. I didn't order at the time which was probably a mistake from a dollar perspective. This was for a Bighorn and I believe the package may change for the higher trim levels.
According to the configurator online the divider is part of BUG - but that could've been a change after your order.
For additional help or confusion. Appears there is a bed divider with ram boxes.
When building a Big Horn
Truck Bed Cargo Divider (Unavailable with some configurations)
Here's what's on the window sticker for my Big Horn:
Bed Utility Group $845
Deployable Bed Step (NAW Multi–Functional Tailgate)
4–Adjustable Cargo Tie–Down Hooks
Pick–Up Box Lighting
Spray–In Bedliner
wondering what those configurations are... only thing i can think of would be the rambox
Spray–In Bedliner
That's a good deal, individually things add up fast. Plus there is a problem if you do the spray in bed liner later with the bed lights / plastic plug and the bed utility rails. For me it's live and learn. I would have added the engine block heater for $95.00. V8 Hemi is very thirsty when cold, that and winter gas.
