Should be able to look on youtube for directions. Don't think it a 12v battery, although I could be wrong. I assume you have the e torquehow does one get behind the seatback on a 2023 quad cab to get to the auxiliary 12 volt battery. Mechanix at cdjr says i am not driving enough to keep battery charged. I am getting p058a code.
There is no AUX 12V battery behind the seat back.how does one get behind the seatback on a 2023 quad cab to get to the auxiliary 12 volt battery. Mechanix at cdjr says i am not driving enough to keep battery charged. I am getting p058a code.
You should be under full warranty, why not let the dealer handle this?how does one get behind the seatback on a 2023 quad cab to get to the auxiliary 12 volt battery. Mechanix at cdjr says i am not driving enough to keep battery charged. I am getting p058a code.
because the dealer says he just wants to charge this battery and it is a 2 hour round trip, dealer said it would take about 4 hours to charge battery.You should be under full warranty, why not let the dealer handle this?
did you have any problem getting the leads from the engine compartment , to the 12 volt auxiliary battery behind the rear seat? This is the battery the ram mechanic wants me to recharge. The truck has about 2800 miles.I would think the two hour drive and back should recharge everything.
I don't drive my etorque much either so I installed a Battery Tender jr. under the hood and plug it in when I'm not going to drive it for a while.
Also, I personally would replace the 12 volt battery also no matter if it tests good.
Etorqes are plagued with battery problems where the battery tests good but it is not.
There is no 12 volt battery behind the seat. It is a 48 volt battery pack and you don't want to mess with it.did you have any problem getting the leads from the engine compartment , to the 12 volt auxiliary battery behind the rear seat? This is the battery the ram mechanic wants me to recharge. The truck has about 2800 miles.
Some info about where to connect the ground (-) wire, Mopar and Deltran instructions/info (body/chassis ground) are in the below thread.There is no 12 volt battery behind the seat. It is a 48 volt battery pack and you don't want to mess with it.
That battery gets charged by the 48 volt generator/motor as you drive. So the best way for you to charge this battery is a good long drive. 2-3 hours.
The 48 volt battery then constantly monitors the 12 volt battery and keeps it charged even while the truck is parked and sitting around, that is why yours discharged.
By hooking up the battery tender to the 12 volt under hood battery it will save the 48 volt battery from going dead trying to charge the 12 volt battery.
So you would simply hook up the battery tender to the 12 volt battery under the hood.
It was quite easy to just buy two metric nuts to add to the battery lugs
I installed the charger on otherside of engine bay and ran wires across the back, leads are quite long.
I had this truck in storage for 6 weeks while on vacation and no issues upon start up.
Thanks for the info. I just went out and changed the location of the battery maintainers negative lead.Some info about where to connect the ground (-) wire, Mopar and Deltran instructions/info (body/chassis ground) are in the below thread.
Resetting battery life in ECU when changed
My experience was very similar. 2021 model that failed at 25 months. I also kept on a trickle charger. Depending on the trickle charger and it's circuitry, it's possible you were overcharging the battery which could lead to early battery failure. If it doesn't have circuitry to sense the...5thgenrams.com
