Aux Switch Panel Question
Gnix
Toronto Ontario Canada
Hi
I have an aux switch panel and I have a wire that’s suppose to wire into the ACC fuse but I can’t find the F66 as others are talking about.
Can anyone tell me which fuse to tap into in my engine bay?
Thank you guys!
Gnix
A bunch of those are probably ignition switched. I'd use something like F44 since its likely rarely (if ever) used.
Thank you detriotm2. F44 works.
Just another question. From what I see on the exterior fuse box cover, there’s fuses marked from 10-30amp fuses but on the actual box I don’t see some of those fuses inserted. Is this normal?
detroitm2
SE Michigan
Yup. Completely normal. They may be for options you dont have, or more likely, the fuse panel is used for a number of different vehicles.
