I believe it only dims when the headlights are on.Thanks, got it. It wasn't red.
Will it auto dim only at night or does that setting dim it all the time?
It dims at night. There is a sensor on the front of the rear view mirror facing out the windshield that checks the light level. It will dim a certain amount depending on the light level. Full darkness, it will be fully dimmed.Thanks, got it. It wasn't red.
It works anytime regardless if the lights are on or off.I believe it only dims when the headlights are on.
same boat like you, i have 5% on top of factory rear windows so it rarely working for me.Is the sensor that checks for light behind you in the rear view mirror glass? I have very dark tinted windows, which I think blocks light from hitting the sensor sometimes. My mirrors do dim, and when they do they work well, but there’s no rhyme or reason to when they dim and when they don’t. Having the dark tint takes care of most of the glare so it’s not a huge deal. I just wish they’d work consistently.
Yup, I had dark tint on my rear window and the auto-dim function rarely came on. The dimming function on the exterior mirrors must be tied to that same sensor, because they rarely dimmed too. My rear window was replaced due to the cracked and leaking rear window surround issue. I have not re-tinted the rear glass and now my mirrors (all 3) function as intended.Is the sensor that checks for light behind you in the rear view mirror glass? I have very dark tinted windows, which I think blocks light from hitting the sensor sometimes. My mirrors do dim, and when they do they work well, but there’s no rhyme or reason to when they dim and when they don’t. Having the dark tint takes care of most of the glare so it’s not a huge deal. I just wish they’d work consistently.
