ramhouston
does anybody know if our trucks have auto brake hold available?
i’m not referring to the electronic parking brake**
I don't think any trim levels have this function.does anybody know if our trucks have auto brake hold available?
Only with the TazerDTdoes anybody know if our trucks have auto brake hold available?
Like how it works, or how to enable it? By default with the 18.1.6 update or higher it's always on. Just push the brake pedal down and hold for a few seconds and you will here the chime, and ABS/Brake lights will flash in the dash, then release the brake pedal. They stay flashing until you hit the gas pedal and start moving.interesting. anybody wouldn’t mind sharing a video on demonstrating it with the TAZERDT?
That is nice a feature, I love thatLike how it works, or how to enable it? By default with the 18.1.6 update or higher it's always on. Just push the brake pedal down and hold for a few seconds and you will here the chime, and ABS/Brake lights will flash in the dash, then release the brake pedal. They stay flashing until you hit the gas pedal and start moving.
does the chime override any audio playing? if so, that would become extremely annoying to deal with.Like how it works, or how to enable it? By default with the 18.1.6 update or higher it's always on. Just push the brake pedal down and hold for a few seconds and you will here the chime, and ABS/Brake lights will flash in the dash, then release the brake pedal. They stay flashing until you hit the gas pedal and start moving.
It only chimes once, not constantlydoes the chime override any audio playing? if so, that would become extremely annoying to deal with.
Never tried this. Does it need to be activated on the Tazer?It only chimes once, not constantly
No, just need the correct software versionNever tried this. Does it need to be activated on the Tazer?
does it mute the radio and override the music though or is that a negative?It only chimes once, not constantly
It doesnt mute radio.does it mute the radio and override the music though or is that a negative?
