I'm looking around for Night edition mirror caps, but the only black caps are 6RP45KXJAA and 6RP44KXJAA. These seem like Diamond Black which I believe is a gloss finish. The mirror caps on my 22' are like a matte black.
looks like you are correct. i just threw out a set off my old bighornIsn’t it the same non painted caps that are on some of the lower trims?
Since Night Edition is available on almost all trim levels you might want to be more specific which trim level you have. The mirror caps on the Night Edition Limited are Diamond Black.I'm looking around for Night edition mirror caps, but the only black caps are 6RP45KXJAA and 6RP44KXJAA. These seem like Diamond Black which I believe is a gloss finish. The mirror caps on my 22' are like a matte black.
This. My Laramie Night Edition is also Diamond, I guess I thought that they all were.Since Night Edition is available on almost all trim levels you might want to be more specific which trim level you have. The mirror caps on the Night Edition Limited are Diamond Black.
the set's i got cost me 80 plus shipping and took about 2 weeks to get to me. perfect match both times. OEM is the only way to go. i recommend watching a few youtube's the first time you do it it's a little stressful getting the mirrors out without breaking them. i have done it 3 times and none broke.I have a 22' Granite Crystalat Bighorn trim.
I'll have a look at that link when I get home today.
Yea, I seen a few. Both with different methods, suction cup or tilt down with a little screw driver. Haven't decided what route to take yet.the set's i got cost me 80 plus shipping and took about 2 weeks to get to me. perfect match both times. OEM is the only way to go. i recommend watching a few youtube's the first time you do it it's a little stressful getting the mirrors out without breaking them. i have done it 3 times and none broke.
i did the tilt it to get the clips and release the mirror. i used a long screwdriver and pried directly on the clip to get it to release then kept tension on it. all you gotta do is get the top 2.Yea, I seen a few. Both with different methods, suction cup or tilt down with a little screw driver. Haven't decided what route to take yet.
Sounds like a plan. I'll try when I all the parts in.i did the tilt it to get the clips and release the mirror. i used a long screwdriver and pried directly on the clip to get it to release then kept tension on it. all you gotta do is get the top 2.
All night editions are black diamond crystal. I have the lowly Big Horn night edition and that's the ones I have.Since Night Edition is available on almost all trim levels you might want to be more specific which trim level you have. The mirror caps on the Night Edition Limited are Diamond Black.
That's weird. I know the BTS versions so use more of a flat black, but I thought others didn't.Yea, they must not follow any rules there. These mirrors have the same finish on both parts. Different from the images above.View attachment 198837
The sport Big Horn and regular big horn come with unpainted caps but when I was looking at trucks the Night Edition big horns had painted caps.That's weird. I know the BTS versions so use more of a flat black, but I thought others didn't.
