Detroitmikeb
- Apr 26, 2023
anyone?
Not a thing.I thought the front/rear balance felt pretty good with the stock bars, and my truck will see mostly road duty, so I probably won't venture into that area. But I wonder about stiffer sway bars putting more twisting load on the frame - is that a good idea?![]()
Funny enough I always wanted the stiffer front bar but recently I decided to remove my front swaybar completely to see what the hype was about and danggg, while you do get some extra body roll it’s amazing going over bumps at an angle and hardly feeling the bump at all! After experiencing this, I really wish Hellwig would actually make an offroad-specific front swaybar that is much lighter rate than the OEM bar but still provides some stability under emergency maneuver situations. I think for now I’ll keep the swaybar off because no front bar and the Hellwig bar in the rear on the middle setting seem to be nearly perfectly in-sync with each other. It’s nice not getting thrown around the cab on off center speed bumps and dips
Surprisingly cornering is nearly the same. The only time I feel it is if I jerk the steering the wheel back and forth. I’m sure it’s not *as* safe, but it doesn’t feel too crazy. It’s really common for SoCal trucks to not run swaybarsYou might disconnect while off-road, but not a good idea on the streets. It may feel “soft”, but it is a little stiffer on the street for several reasons. Corner control being one of them.
