mplaramie
- Aug 10, 2023
If you want the 35x12.50 tire, you need to get a slight negative offset wheel like @H2OMAN mentioned. The less tire width while keeping the larger diameter, the more you can go with a 0 or positive offset. Really depends how much poke you want. Also, I think the factory wheels are a +19 offset.Thank you so much for the awesome info and response- I really appreciate it. After reading your recommendations (as well as a few others) I definitely will be opting for the 18's. I couldn't agree more with your take on lift height and true capability- so many guys think taller is better and suffer on the trails. Hence why I opted for the 3-inch lift ( I figure it's a good compromise between a strict level kit and a 4 inch suspension lift). One last question, what is your opinion on the BDS recommended tire size of 33x 12.5s vs 35x 12.5's on this 3 inch lift? My last ram I installed the Bilstein level and ran 275x65 R20 with no rubbing. Definitely not trying to stuff the largest tires possible and would prefer to not rub. Again, thank you so much.
Hope this makes sense and I don't have it wrong.....
