If my math is right, based on transmission gear ratios given in the FSM, engine RPM will increase about 300 over your stock 3.92 ratio gears at 70MPH in 8th gear.
I would guess that your 2wd with e-locker (aka open diff unless you flip the switch) is already trying to break the tire loose with any moisture on the ground or a strong turn. What size rubber are you running in back? Ditto on stevj- you’ll be running 16% higher rpm for any given speed/gear.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
