Anyone running 4.56 gears?
Firebird
I have been interested in these gears for a while. Is anyone here running them? I would welcome any feedback, thanks.
I would guess that your 2wd with e-locker (aka open diff unless you flip the switch) is already trying to break the tire loose with any moisture on the ground or a strong turn. What size rubber are you running in back? Ditto on stevj- you’ll be running 16% higher rpm for any given speed/gear.
I’m running the stock 22” wheels and tires. I do not remove traction control in the rain, and I don’t run on the hwy very often.
