Anyone remove their leveling spacers/kit before?
Bellpa
Pittsburgh, PA
Quick question for those that have had front leveling spacers installed by a shop. Anyone remove them on their own? And if so, did you have to remove as much as you need to like for the install? Basically, is it easier to remove than install them...
Should be the same process to remove as install. Installation requires removal and replacement of the strut assembly. Removal of the spacer will be the same. Make sure to have the front alignment checked if you remove the spacer.
I figured it was the reverse same as install, but wanted to check to see first. Thanks for the reply.
