Anyone else have fuel gauge issues?
mntgoat
My fuel gauge is showing empty again. It has done this 4 or 5 times for a few weeks and then it fixes itself.
The dealer has never figured out the issue and I'm out of warranty now.
Anyone else have this issue?
Kiwiaudio
Ohio
Try a different dealer. If the first one has the issue documented prior to warranty expiration, you should be good. Ask another dealer !
TittoPollito
About every 415 miles I have the same issue...In all seriousness check the wiring harness leaving the top of the tank. I had a Dakota back in the early '00 that started doing that, after a bunch of searching and poking around I found a small worn spot in the wire that would ground out and make the gauge read empty
