Any success with aftermarket tail lights for ‘22 1500
BoiseD
I have tried two different aftermarket LED tail lights to replace my factory halogen tai lights on my ‘22 1500 Big Horn. First was Alpharex- the brakes and blinkers worked, but when I would turn my headlights on at night, the running tail lights would not work. Then I installed the Spec-D tail lights- they worked fine for a few days, then I got the “right blinker tail light out” message. My running tail lights work when head lights are one, but right turn signal, brake light, and reverse light do not work. Left tail light is fully functioning. I did not initially install the resistors that came with it, and when I installed them after the right light went out it did not fix the issue.
I really want black housing, smoked lense tail lights for my truck. Has anyone had success with smoked out tail lights and if so, which ones?
I had the morimotos on my 2019. Never had a problem with them.
Did you re program the BCM to let it know you have LED lights? Use AlfaOBD or jScan to change all lights to LED.
I did not change anything. I believe they are only for non Led trucks. I had the LED headlights, 4 banger fogs and the Tail lights. My truck was NON LED originally and everything was plug and play, no programming.
My left alpharex low beam is currently not working. It comes and goes while the right one works fine. Do you think me changing on AlphaOBD would help this?
I went from halogen oem lights to the alpharex aftermarket’s. Thanks!
