I live in Fairbanks and the winter will be here shortly. The question i have is. Do I need to change the factory radiator fluid for the winter or is it already mixed accordingly?
Is the truck new or a few years old. If run for a while, find the chart for the proper mix and change out. If pretty new, U can drain off some and add concentrate. The RAM Dealer up there should be well versed on this ref anti-freeze and temps and assist U. U also gotta know which anti-freeze U R running. OAT/HOAT, conventional and add correct stuff, because U cannot mix OAT OR HOAT with anything else. Again, yer RAM dealer up there should help U. Attaching anti=-freeze chart ref mixtures and temps, for general knowledge.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
