AlbertaClipper
- Aug 8, 2021
Glad I was wrong - I missed that in there. Thanks for clearing it up. Def. rather be wrong in this case.That's regarding the diesel engine, not the Hemi.
He has spoken. No need for any further replies, especially if you have a differing opinion.There is no proof that idling causes lifter failures, just speculation based on the amount of cop cars with lifter failures so people start jumping to conclusions and think that cop cars = iding = failure. There is also no proof that idling doesn't cause failures, but there are other theories; cars that idle extensively are required to use the "extreme duty" maintenance cycle which is changing the oil at 320 hours. If a cop car runs 24/7, that means it should be getting oil changed every 2 weeks. If it runs half a day it needs to change every month. Many police depts don't follow that schedule, so the bad/dirty oil starts to form deposits on the needle bearings of the lifters and they sieze up, eventually the lifter takes out the cam lobe and its game over.
There are Rams that have over 1000 idle hours with no lifter failure (see "high mileage edition" in the "truck central" youtube channel), and some that fail with < 20,000 miles.
The lifters are primarily lubricated via pressurized oil galleys, not crank splash. This design has not changed since 2003 when the hemi was re-introduced, so if we needed to depend on crank splash for lifter lube then the pre 2009 hemis would be having lifter failures as well, which they don't; therefore it's not a crank/splash problem.
We have also seen an analysis of failed lifters/cams from a metallurgy specialist and he basically said that oil was present, but was not effective ("insufficient lubriscosity" IIRC).
Basically the best prevention is: change your oil frequently (< 8000 miles), use 100% synthetic, and if you're really into it (but ok with voiding warranty) run something like Redline 5w-30.
Another theory; the hemi's were originally designed for 5w-30, but dropped to 5w-20 to improve fuel efficiency. Nothing in the design changed when they dropped the oil weight, and the manual for a period of time even still "allowed" you to run the 30 weight. This theory says that the 20 is too thin and that would be partially backed up by the specialist report mentioned above.
There is concern of not idling too long because of the oil splash thing, not getting enough upper end lubrication due to the engine design. But they have these engines in police and work vehicles that may idle for hours daily, with no special consideration compared to civilian versions in terms of idle lubrication.
40 minutes is barely more than your average day being stuck in congested traffic in any busy city in the US. Heck, I spent literally 25 minutes yesterday in an In N Out drive thru line waiting for a couple of burgers and fries. Almost all of that idling with zero throttle since I'm just letting off the brake to creep forward in line.
Seen the Chick-fil-A drive thru line at lunch or supper time?
Oh yeah, there are actually two locations in San Diego county that has both a Chick Fil-A and In N Out right next to each other. The line of cars is in the streets pretty much all the time.
Hello PotIf you're going to take every argument personally you're going to have a rough time on the internet. It's sunny outside, take a walk, kiss your wife...
Hello Pot
Stop making sense- we won't have any of that around here...There is no proof that idling causes lifter failures, just speculation based on the amount of cop cars with lifter failures so people start jumping to conclusions and think that cop cars = iding = failure. There is also no proof that idling doesn't cause failures, but there are other theories; cars that idle extensively are required to use the "extreme duty" maintenance cycle which is changing the oil at 320 hours. If a cop car runs 24/7, that means it should be getting oil changed every 2 weeks. If it runs half a day it needs to change every month. Many police depts don't follow that schedule, so the bad/dirty oil starts to form deposits on the needle bearings of the lifters and they sieze up, eventually the lifter takes out the cam lobe and its game over.
Same way at Chick Fil A, line moves pretty quick though. One thing about the Etorque is it not only shuts off at red lights but also while waiting in line at the drive though.Oh yeah, there are actually two locations in San Diego county that has both a Chick Fil-A and In N Out right next to each other. The line of cars is in the streets pretty much all the time.
Oh, you so funny. I bet you crack yourself up all the time. Probably should leave comedy to comediansExplains a lot actually, you should put it down, smoking is bad for your health.
Someone's a bit bitter. Tries calling me out for taking things personally, bit is taking a little joking way more personal. It's the internet, lighten up Francis.And you should leave your drama to the school girls. You left your first pithy little reply to me in this thread just because I left my opinion, not because it's wrong.
If you disagree with what I said in my post then point out where you do. No need to be bitter here just because you were wrong about our gear ratio discussion.
There was another guy who did that to me months after an argument, life is way to short to put up with that drama so if that's your thing then you're welcome to hang out with him in my blocked users list.
No hard feelings. Just pushing buttons since you are easy to trigger and think your opinion is the only one that matters.Exactly, next time you should leave a previous argument and your obvious hard feelings in the past.
