Hey everyone,
Recently I modified my 2023 ram 1500 (new body) with the 9 speaker alpine system with 12" screen. Here is what I've done so far.
Infinity Reference REF-9633IX 6x9 3-Way Coaxial in rear doors. Direct fit. They overpower everything else. Very bright.
Powerbass OE-690D 6x9 Midbass in front doors. Direct fit with the Infiniy spacers. Wired down to 2 ohms. Midbass only because of the alpine amp eq. (Replaced with another set of Infinitys. Some reason this killed the volume on my front doors and dash speakers)
Infinity Reference 3032cf 3.5-Inch in the dash.
Skar vehicle specific dual 12" box loaded with VD-12D, powered by Skar Audio RP-1200.1D which I got the LOC signal from the black wires on the metra kit that goes under driver seat.
Volume is lacking from the doors. I'm thinking I need to add a amp to them. I have a few questions.
Will removing the door speakers from the alpine system trigger the no speaker issue where it stops all volume?
Can I tap into the metra harness under the driver seat for the LOC just like I did for the sub amp? I am not sure which wires are actually needed. I know I can tap into the a-pillar for the rear door speakers, but the harness is much easier if I can.
Is there a better way to get signal from the HU? I dont believe metra has changed its harness for the new plugs yet. Would also save me 350$...
I do have a fosgate DSR1 laying around, but would need the wiring. (Per Maestro, incompatable with my vehicle)
Thanks!
Thanks!
