Couchsachraga
- Aug 12, 2018
Since I've had the truck for a week I'm finally finding time to start a few "necessary" modifications... one of which is adding my IC2820.
Right now I'm planning on using mag mounts on the roof (not the best, but if the antennas are up there I need to be able to move them when I have canoes on the roof). Rather than use my favorite Larsen 2/70 I'm switching to 1/4 waves for VHF and UHF... in theory in access mode I can make it in to the garage without the antennas getting tweaked TOO much.
Looking at where to route the antenna wires, there is a plug just to the rear of the floor storage boxes that looks promising. From there under the floor (likely along the box for protection). At the moment I'm planning on the radio being under the passenger seat or hopefully under the center seat (bench seat Laramie).
Another option would be to run the coax through the rubber plug along with the eTorque battery cables, but I'd like to stay away from those if I can.
Hopefully this post will be helpful to others.
