i have read that my 2021 5th gen level one 1500 laramie should work with ACC. But i get a code saying there is an issue with the ABS. Are there different ABS modules that don't work with ACC?
Where have you read that it should have ACC? Unless there was a change for 2021, Laramie Level 1 did not come with ACC. It's easy enough to check your build sheet and see if it is listed there.
I am looking to add adaptive cruise to my 2020 RAM Bighorn, can you tell me if you already had the wiring harness from the rearview mirror down to the CANBUS?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
