Bansheeman6100
- Apr 15, 2022
I purchases AlphaOBD, the bypass and dongle to adjust the truck for larger tire size, as well as see if I can fix an issue im having with the TPMS. since I've installed the new 35s (10 ply) and American racing wheels, my TPMS works maybe 2% of the time. And even then, it will only pick up a single sensor sporadically. I did reset the system, and it read all 4 sensors and the light stayed off for about 5 miles. Then, bamb, back on. I worked in a tore shop for years, and saw this once in awhile with 10ply tires of half ton trucks. Are the receivers on the truck side just not strong enough to make it through the thicker combo, thats also more distant? Is there any way to increase the receiver strength?
