Nels
After a lot of reading and studying I finally replaced the Readylift spacer lift with adjustable ride height shocks about 6 months ago on my 2019 Laramie. Had run that setup for 75,000 miles. Chose the eibach pro sport adjustable shocks. Love the ride. Everything is great. Except - i had an alignment done after install, just because I felt i should with some geometries changing. The alignment seems fine, but my steering wheel is off center by about 10 degrees. I dont know the mechanics of this but I imagined that was just some kind of oversight by the tech that did the job. So I wnt back to the same shop asking for that to be rectified. He claimed to have done a full alignment again. I left the shop late for my next appointment, only to find the steering wheel was still in the same "crooked" position. I made another appointment and went back a 3rd time, clearly explaining that I was there ONLY to get the steering wheel issue corrected. The tech had it in the shop for another hour, came back and said he's done everything he can do. The truck is in perfect alignment, and he can't understand why the steering wheel isn't straight. I am a.banker by trade and have no idea how the linkage between the suspension and the steering wheel works. Is this possible that my steering wheel cannot be straightened? Or would it be as simple as taking it to another shop to be corrected? Does it have anything to do woth the Eibachs?
Appreciate any insight.
