Another Money Pit
So I had to put a .25 wheel Spacer on my stock 21 Laramie rim to prevent tire rub on my uca after adding a 3.5 lift kit. I think I already know the answer to this but I thought I would ask the truck guru's on here. So will I need to get another alignment or will the .25 Spacer not effect that at all? The only time the tire rubbed was when I was going around tight corners at high speed and my ABS light would come on
Thanks
Thanks
