AlfaOBD
I have a question. When you do a change in AlfaOBD that has multiple changes like adding a brake controller do you only change one option at a time and exit everything and then go back in or can you do all the changes at once then exit everything?
Old post, but I thought I'd share my experience. I don't think that matters as long as you wait for each operation to display the "completed" message. I did all in one sequence, one option after another. Turned the truck off and immediately on. Worked like a charm.
I agree, I haven't had issues changing multiple things. The only delay I've experienced, is when you enable anything that gets displayed on the UConnect screen, say for example, automatic wipers..that takes a few cycles, or overnight, in order to update.
I think that's a matter of the UConnect model you have. If you have the "connected" one (Nav, SOS button etc). these seem to process the changes longer. My non-nav unit responds immediately after truck restart.
Makes sense. I read somewhere similar results.
Will the alpha obd chamge the settings for the gas tank to read properly as well ? Fix the 26 gallon reading 23 yadda yadda
Yes. All you do is edit the fuel capacity size (it’s in liters). I just moved from a 26 to the 33gal tank and that’s all I had to adjust to make the range to empty value show proper. The fuel pump is the same between the two so didn’t need to adjust any of those values.
However for you if you go from 23 to 26 you will need to check the fuel tank sensor values because the fuel pump is different between those two.
Dixit
Dixit
Did you need new lines or anything or did everything line up with the bigger tank?
There’s a whole thread on this. Goes into a lot of details as well as parts needed.
Retrofitting the 33 gallon tank
I just purchased AlfaOBD and my OBDLink should be here on Jan 3rd.
I have alfaobd, and most options work, even though you have to pick 17 model year. Anything in the BCM seems to work. I think thats where you enable the factory brake control outputs, etc.
You should be able to use it to enable brake control. The developer, Alec, is very responsive, you should ask him.
Successfully installed and programmed my after thought factory brake controller tonight using Alphaobd.
@downsjh I appreciate your message about the order to do it in.
Hooked up the camper after install and all is functioning just as it should.
thanks
Anyone know how to remove the nav in motion?
Tazer DT sounds like it will. AlphaObd, tech support says it will, but know one can find on several forums where you can change to Nav on the move through AplphaObd software. On Tazer DT it is in Active side of the computer so you have to leave the device plugged in. I didn't think it was a big deal leaving Pedal commander and Hyper-tech speedometer correction active until the truck would not start, and needed towed. I didn't have the lights, tools or device to deactivate. Now I need to re-certify Hyper-tech with a copy of the Invoice on repair.
Yes my TazerDT works to remove the nav in motion lockout but its a pain in the *** and it removes other functions when that is enabled.
Just got my AlfaOBD working. There is a lot of things it can change.
ECU Part Number: 68287182AG
Hardware number: 68287182AG
Hardware Supplier Identification: Continental
Software Logical Block Supplier Identification: Continental
Active Diagnostic Status Of ECU: Running in Application mode
Gateway: Yes
Plant/Service Mode Parameters: Shipping Status: Customer Mode
Vehicle Configuration Programmed Status: Yes
Last Programmed Status: Manufacturing
After Market ECM Detected: Default
ECU Qualification:
Sense-Ambient Light Dimmer Wheel: Yes
Sense-Reverse Switch: No
Sense-Door Lock Switch Front Driver: No
Sense-Door Lock Switch Front Passenger: No
Sense-ERS Switch: No
Sense-Flipper Glass Ajar: Yes
Sense-Fuel Level Sensor #2: No
Sense-Hood Ajar Switch: Yes
Sense-Hard Top/Stealth Input: No
Sense-Liftgate/Trunk Ajar: Yes
Sense-Trunk/Flipper Glass Release Switch: Yes
Sense-Rear Wiper Park Switch: No
Sense-Washer Fluid Level: Yes
Sense-Flipper Glass Release/Sunshade Switch: Yes
Sense-ESP Off Switch: No
Sense-Cargo Lamp Switch: Yes
Police Passenger Unlock Motor Present: No
Control-Headlamp Leveling: No
Control-Baggage Comp Lamps: Yes
Control-Diesel Cabin Heaters 1-3: No
Control-ESCL: No
Control-Diesel Fuel Heater Relay: No
Control-Flipper Glass #2: No
Control-Foot Well Lamps: Yes
Control-Front Fog Lamps: Yes
Control-Headlamp Washer Motor: No
Control-Passenger Airbag Off LED: No
Control-Rear Fog Lamps: No
Control-Rear Turn Lamps: Yes
Control-Rear Wiper Motor/Flipper Glass #1: No
Control-Run/ACC Relay #2: Yes
Control-Side Repeaters: No
Control-Sunshade: No
Control-Trunk/Flipper Glass Relay: Yes
Control-UGDO Feed: Yes
Control-Trailer Tow: Yes
Control-Dedicated DRL: No
Control-VTA Indicator Request: Yes
Control-Passenger Airbag LED: No
Adjustable Pedals Present (Non-memory): Yes
Inverter Present: No
Intrusion System Present: No
Remote Start Present: Yes
Tip Start Present: Yes
HID Headlamps Present: Yes
Auto Headlamps Present: Yes
Rain Sensor Present: No
Remote Compass Present: No
EC Mirror Present: Yes
Cruise Feature Present: Yes
RKE System Present: Yes
SKIM System Present: No
Police Vehicle: No
Military Lighting: No
AC Present: Yes
Rear Doors Present: Yes
Electronic Shifter Power Feed Present: Yes
______________________________________________
Customer Customisable Configuration set in the Body Computer:
Customer Programming Features:
Unlock all doors on 1st press: Set
Sound Horn on Lock: Set
Flash Lamps on Lock: Set
Headlamps on with Wipers: Set
Auto Lock: Set
Auto Unlock: Set
Door Alert Enable: Not set
Auto Wipers: Not set
Illuminated Approach Time: 30 sec
Headlamp Delay Time: 30 sec
Accessory Delay Time: 45 sec
Ambient Dimmer Level: 0.50 %
Daytime Running Lamps: Set
EC Mirror Auto Dim: Set
PE Unlock All Doors or Approach Door: Not set
Accessory Delay Active: Not set
Remote lowering horn enabled: Not set
Remote lowering lights enabled: Not set
Sound Horn on Remote Start: Set
Auto Relock: Set
Static Gridlines Enabled: Not set
Dynamic Gridlines Enabled: Not set
Sound Horn On Lock Status: Chirp on 1st press
Customer Programming Switches:
Rear View Camera Dynamic Grid Lines Enabled: Not set
LIN Module Customer Programmable Features:
Rear View Camera Static Grid Lines Enabled: Not set
Rear View Camera Dynamic Grid Lines Enabled: Set
Vehicle Configuration set in the Body Computer:
Vehicle Config 1:
Model Year: 2019
Vehicle Line: Not defined
Country Code: USA
Left/Right Hand Drive: Left Hand Drive
Remote Start Present: Set
Drive Configuration: Selectable 4wd
Emode Present: Not set
Auto High beam: Not set
Body Style: 4-Door Pickup
Maximum Vehicle Speed: 248 km/h
Shifter Type: 4 pos Rotary Eshifter PRND (DS)
PTS Display Type and Location: Headliner or NO Display Programmed
Performance Pages Present: Present
Special Packages: Sport/SLT+/Laramie
Headrest present: Not set
UREA/SCR System Present: Not set
PTS Configuration: Front and rear
Rear View Camera: Set
CHMSL camera: Not set
Hill Descent Feature Present: Not set
Select Speed Control Feature Present: Not set
Vehicle Config 2:
Power Inverter Type: No
Thatcham Present: Not set
Run flat tires present: Not set
Maserati vehicle mode: Normal
Pass. Airbag Disable Switch Present: Not set
Rain Sensor Present: Not set
SKIM System Present: Not set
Air Conditioning Present: Set
Cruise Feature is Present: Set
Flipper Glass Present: Not set
Full Size Spare: Not set
Off Road Capable: Not set
Special Packages: Not defined
Special Packages: Bighorn
ECO Indicator Present: Not set
Drive mode feature configuration: Not set
Memory drive mode sub-feature configuration: Not set
ESC drive mode sub-feature configuration: Not set
ECM drive mode sub-feature configuration: Not set
Secure park feature present: Not set
Performance & Gear Shift Indication: No
Maximum Load Inflation Pressure Rear Tire: 36 PSI
Maximum Load Inflation Pressure Front Tire: 36 PSI
Light Load Inflation Pressure Rear Tire: 0 PSI
Light Load Inflation Pressure Front Tire: 0 PSI
Vehicle Config 3:
Police Lighting Feature: Not set
Power Lift Gate Present: Not set
Power Right Sliding Door Present: Not set
Power Left Sliding Door Present: Not set
RKE System Present: Set
Sunshade Present: Not set
T-Case Type: Tranfer case 133 / Transfer Case BW 44-44
Fuel Capacity: 98 Liters
Wheel Base: Not defined
FOBIK Safe Enable: Set
ELV Present: Not set
Window Express Feature Configuration: All windows express feature
Adjustable Pedal Feature Present (non-Memory): Set
Auto Headlamp Feature Present: Set
Door Alert Feature Present: Not set
Two Fuel Sending Units Present: Not set
Vehicle is an SRT: Not set
Disable Display of Radio Clock: Not set
Chassis Type: Type 31
Display Outside Temperature Present: Set
HVAC Configuration: Dual Zone ATC
Vehicle Brand: Ram
Display Compass Heading Present: Set
Interior EC Mirror Present: Set
ESCL system present: Not set
High Intensity Discharge Head Lamps: Set
Secondary Lock Present: Not set
Liftgate/Trunk Type: Trunk
Collision Mitigation System present: Not set
Forward Collision Warning present: Not set
Base TPM system present: Not set
Premium TPM system present: Set
Paddle Shift Feature Present: Set
Sport Mode Present: Not set
Auto Park Present: Set
Passive Entry Present: Not set
Keyless Go Present: Set
Vehicle Config 4:
Transfer Case High Ratio: 1.00
Axle Ratio: 3.21
Transfer Case Low Range Reduction Ratio: 2.64
Dynamic Tire Circumference: 2640.00 mm
Vehicle Config 5:
Steering Ratio at zero: 0.00
Steering Ratio at Positive Angle 1: 0.00
Steering Ratio at Positive Angle 2: 0.00
Steering Ratio at Positive Angle 3: 0.00
Steering Ratio at Positive Angle 4: 0.00
Steering Ratio at Positive Angle 5: 0.00
Luci feature present: Not set
Dual Rear Wheel (DRW) Vehicle Present: Not set
Non-Regulated Tire Pressure Information System: Not set
Ambient temperature sensor location: CBC
Rear door lock switch present: Not set
Wait to Start Feature Present: Not set
Speed Limiter Present: Not set
Seat Belt Reminder Module Present: Not set
Child Display Feature Present: Not set
Off-Road Pages Present: Not set
Ambient Lighting Feature Present: Set
Semi-Automatic Parking System Present: Not set
Park With Stop Present: Set
Vehicle Config 6:
Steering Ratio at Negative Angle 1: 0.00
Steering Ratio at Negative Angle 2: 0.00
Steering Ratio at Negative Angle 3: 0.00
Steering Ratio at Negative Angle 4: 0.00
Steering Ratio at Negative Angle 5: 0.00
Dynamic Tire Circumference Front: 0 mm
Analog Door Sensor Configuration: No Doors with Analog Sensors
Brake type configuration (M156/7): Signal Not Available
Air Quality System Present: Not set
Vehicle Config 7:
Lane Departure Warning present: Not set
Transmission drive mode feature: Not set
Paddles lock-out feature: Set
Dynamic steering torque present: Set
Super trac pack present: Not set
E-shifter present: Set
Automatic transmission type: ZF 8 Speed
Shift feature autostick / electronic range select: ERS
Teen Key Feature Present: Not set
Full Central Vision Processing: Not set
Full Speed Range forward collision warning plus system present: Not set
Type of adaptive Cruise Control (ACC) system present: No
ASCM contains suspension: Not set
ASCM Active Damping: Not set
Transmission Neutral Hold Feature Present: Not set
Red Key Feature Present: Not set
Active Blind Spot Present: Not set
Axle Locker Configuration: No Axle Locker
Transmission Type: Automatic
Park Brake Type: Integrated EPB (Motor On Caliper)
TPMS Configuration: NHTSA enable warning
Vehicle Config Customer Settings Menu 1:
Park Assist customer settings menu: Absent
Park assist brake customer settings menu: Set
Park Assist Front Volume customer settings menu: Set
Park assist rear volume customer settings menu: Set
Electric power steering customer settings menu: Not set
Forward collision warning customer settings menu: Absent
Forward collision mitigation braking customer settings menu: Not set
Sound horn with remote lock customer settings menu: Feature 2 - 3 option
Sound horn with remote start customer settings menu: Set
Sound horn with remote lower customer settings menu: Not set
CHMSL line customer settings menu: Not set
Auto-On Driver Comfort CSM: Feature 2 - 3 option
Auxiliary Switches CSM: Absent
Rear view camera gridlines customer settings menu: Static + dynamic
Police Passive Entry Settings CSM: Not set
Power accessory delay customer settings menu: Set
Adaptive front light system customer settings menu: Not set
Ambient dimmer customer settings menu: Not set
Tire jack mode customer settings menu: Not set
Air suspension warning customer settings menu: Not set
Automatic aero mode customer settings menu: Not set
Auto high beam customer settings menu: Not set
Auto park customer settings menu: Set
Blind spot alert customer settings menu: Not set
Capacity unit customer settings menu: Not set
Clock display customer settings menu: Set
Compass calibration customer settings menu: Not set
Consumption unit customer settings menu: Set
Distance unit customer settings menu: Set
Auto door lock customer settings menu: Set
Auto door unlock customer settings menu: Set
Daytime running lights customer settings menu: Set
Easy exit seat customer settings menu: Not set
Auto entry exit mode customer settings menu: Not set
EPB service mode customer settings menu: Set
Flash lamps with lock customer settings menu: Set
Headlamp drop customer settings menu: Not set
Headlamp off delay customer settings menu: Set
Headlamps on with wiper customer settings menu: Set
Hill start assist customer settings menu: Set
Illuminated approach customer settings menu: Set
Lane departure torque customer settings menu: Not set
Lane departure warning customer settings menu: Not set
Flash lights with remote lower customer settings menu: Not set
Nav turn by turn customer settings menu: Not set
Passive entry customer settings menu: Not set
Performance shift enable customer settings menu: Not set
Performance shift rpm customer settings menu: Not set
Power liftgate chime customer settings menu: Not set
Power unit customer settings menu: Not set
Pressure unit customer settings menu: Set
Power take off customer settings menu: Not set
Rain sensitive wipers customer settings menu: Not set
Rear camera customer settings menu: Not set
Vehicle Config Customer Settings Menu 2:
Rear view camera delay customer settings menu: Set
RKE linked to memory customer settings menu: Not set
RKE unlock customer settings menu: Set
Speed unit customer settings menu: Set
Tilt mirror in reverse customer settings menu: Set
Torque unit customer settings menu: Not set
Trailer selected customer settings menu: Not set
Trailer name customer settings menu: Not set
Trailer type customer settings menu: Not set
Transport mode customer settings menu: Not set
US/metric customer settings menu: Not set
Wheel alignment customer settings menu: Not set
Fuel Saver customer settings menu: Set
Tempature Unit customer settings menu: Set
Hold And Go customer settings menu: Not set
Auto Power Folding Mirrors customer settings menu: Not set
Paddle Shift CSM: Not set
Speed Warning CSM: Absent
LDW On/Off CSM: Not set
Park Assist Type CSM: Not set
EPB On/Off CSM: Not set
Passenger Airbag On/Off CSM: Not set
FCW Switch CSM: Not set
CBC Configurable Inputs and Outputs:
Ambient Light Dimmer Wheel Input Present: Set
Backup-Reverse Switch Input Present: Not set
ERS Switch Input Present: Not set
Fuel Level Sensor #2 Input Present: Not set
Hood Ajar Switch Input Present: Set
Inverter Status Input Present: Not set
Manual T-Case Present: Not set
Snow Plow Enable/Disable: Not set
Washer Fluid Level Sense Signal Input Present: Set
ESM Present: Set
Adjustable Pedal Motor Relay Output Present: Set
Diesel Cabin Heater #1 Output Present: Not set
Diesel Cabin Heater #2 Output Present: Not set
Diesel Cabin Heater #3 Output Present: Not set
Diesel Fuel Heater Relay Output Present: Not set
Right Dedicated DRL Lamp Output Present: Not set
Left Dedicated DRL Lamps Output Present: Not set
Foot Well Lamps Output Present: Set
Front Fog Lamps Output Present: Set
Headlamp Washer Motor Control Output Present: Not set
Inverter Enable Relay Output Present: Set
Relay LSD Spare #1 Output Present: Not set
Relay LSD Spare #2 Output Present: Not set
SNOW PLOW LSD #3: Set
IOD ON LSD Output Present: Not set
Snow Plow Park Lamps: Not set
Rear Fog Lamps Output Present: Not set
Rear Park Lamps Output Present: Set
Rear Turn Lamps Output Present: Set
Rear Turn Lamp Output Present (NA on LA): Not set
Run-ACC Y Relay #2 Output Present: Set
Side Repeaters Output Present: Not set
Ram Box/Tail Gate Lock Present: Not set
Ram Box/Tail Gate Unlock Output Present: Not set
Trailer Backup Lamps Output Present: Set
Trailer Tail Lamp Relay Ctrl Output Present: Set
Trailer Turn_Stop Relay Ctrl LT Output Present: Set
Trailer Turn_Stop Relay Ctrl RT Output Present: Set
UGDO Feed Output Present: Set
VTA Warning LED Output Present: Set
Vacuum Switch Input: Not set
Ignition UNLOCK RUN START Present: Set
IOD RELAY OFF HSD Present: Not set
IOD RELAY ON HSD Present: Not set
Ambient Temperature Sensor Present: Set
CBC Features Configuration:
Tip Start Enabled: Set
Dual Start Relay System Present: Not set
Wiper Service Position Enabled: Not set
AUX High Beam Present: Not set
Trailer Tow Present: Set
Quad Headlamps Enable: Set
Horn Chirp Allowed: Set
Bi Xenon Headlamps Enable: Not set
Hazard Lamp Configuration: Latching Switch
Park Lamp Loadshed Enable: Set
Front Fog Lamp Dropout Enable: Not set
Combined Rear Lighting Enable: Not set
Side Repeaters Enable: Not set
One Touch Lane Change: Set
Exterior Light Loadshed Enable: Set
Front Wiper Park Enable: Set
Rear Wiper Park Enable: Not set
Reversible Washer Pump Enable: Not set
Single Element Tail Lamp: Not set
DRL Configuration: No
DRL Lamp Location: Low Beam DRL
DRL Dropout Enable: Not set
Tunnel Detection: Not set
Rear Lighting DTC Disable: Not set
LED Reverse Lamps Present: Not set
LED Stop Lamps Present: Not set
LED Rear Turn Lamps Present: Not set
LED Tail Lamps Present: Not set
LED Rear Fog Lamps Present: Not set
LED License Lamps Present: Set
LED Front Turn Lamps Present: Not set
LED Front Fog Lamps Present: Not set
LED Dedicated DRL Present: Not set
LED Low Beam Lamps Present: Not set
LED High Beam Lamps Present: Not set
LED Front Park/Marker Lamps Present: Not set
VTA Hood Ajar Monitoring: Not set
TCSM Present: Set
Headlamp Wash Spray Duration (at 100 ms intervals): 1100 ms
Headlamp Wash Interval: wash cycle #11
Headlamp Wash Shot: Single
Front Wiper Wipes After Wash: 2 Wipes
Headlamp Washer Low Fluid Shut-Off Enable: Set
Side Mirror Repeaters used as side markers: Not set
Intermittent Wiper States: 4 Intermittent Wiper position Switch
LED CHMSL Lamp Present: Not set
ECU Configuration 3:
Configuration messages status 3: Not Programmed
Rear Camera Present: Set
DRL customer setting enable/disable: Set
Front Heated Seats Present: Set
Front Ventilated Seats Present: Not set
Destination: United States of America
Cabin Equalization Curve Number: Not defined
Hill Start Assist Customer Setting Option Present: Set
Radio APPS/Clari-Fi Present: Not set
SDAR Travel Link Feature Present: Not set
DAB/DMB Present: Not set
Heated Steering Wheel Present: Set
Surround Sound Feature Present: Not set
Power Door Locks Present: Set
Antenna Type: Active Primary and no secondary antenna
Disable CD Eject: Not set
DTV Front Camera Present: Not set
DTV Side Camera Present: Not set
Steering Wheel Switch Configuration: Core Steering Wheel
Radio Display On/Off Softkey Present: Not set
Microphone Tuning Parameter: Absent
Microphone Configuration: 2 microphones
Microphone Type: Peiker 300 mv
External Port Type: Splash Screen Type: None/Vehicle Brand
ECU Configuration 4:
ERS Available: Set
Rear Wheel Dually: Not set
Max Gear: 8
IPC Feature Configuration: Not available
Heated Seat Present: Set
Split Shaft Present: Not set
Vehicle Class: 5500
Fuel Capacity: 0 Liters
Gear Display: Disabled
Wireless Configuration:
Tip Start Present: Not set
AP5 Trunk: Smart Switch
Airport Scenario Trunk Set: Not set
AP1 Left Front: Not present
AP2 Right Front: Not present
AP3 Left Rear: Not present
AP4 Right Rear: Not present
Doors Configuration:
Global Up: Not set
Global Down: Not set
Sun Shade: Not set
Puddle Lamp Present: Not set
Rear Door pre short drop behavior: Not set
Passenger Window Lockout: Set
Folding mirrors present: Set
Heated Mirrors: Set
Mirror turn signals present: Set
Driver Memory Mirrors Present: Set
Passenger Memory Mirror Present: Set
Electro-chromatic driver mirror present: Set
Electro-chromatic passenger mirror present: Not set
Tow Mirror Present: Not set
Blindspot Mirror Present: Not set
Mirror Approach Lights Present: Set
Door map pocket LED present (Ambient Lights): Not set
Door Courtesy Lamps Present: Set
Window Motor Type: Set
Window Hall Sensors Present: Set
Door handle LED present (Ambient Lights): Not set
Frameless Window Present: Not set
Memory Configuration:
Memory Adjustable Pedals Present: Not set
Tilt/Telescope Steering Present: Not set
Memory Seat Present: Not set
Rear Heated Seats Present: Not present
Front Vented Seats Present: Not present
Heated Steering Wheel Present: Present
Heated Seat Material Type: Default
Heated Wheel Material Type: Wood/Leather
Brake Configuration:
Wheel 18 inch overall ESC Maserati: Not set
Powertrain Configuration:
Vehicle is equipped with Dosing Control Unit: Not set
Vehicle is equipped with Variable Geometric Turbo: Not set
ECO Mode Configuration: Remember previous state with Ignition Key Cycle
Dual Alternator Present: Not set
Safety Configuration:
ODS Present: No
ORC - Special Type: Not defined
ORC - Calibration Selection: Not defined
Integrated EPP Present: No
BUX vehicle: Yes
CBC Exterior Lighting Calibrations:
Auto Headlamp ON Threshold: 3.33 V
Auto Headlamp OFF Threshold: 2.53 V
Left Side DRL Voltage Target: 12.2 V
Right Side DRL Voltage Target: 12.2 V
Left Low Beam Voltage Regulation: 13.6 V
Left High Beam Voltage Regulation: 13.6 V
Right Low Beam Voltage Regulation: 13.6 V
Right High Beam Voltage Regulation: 13.6 V
Left Front Corner Voltage: 13.6 V
Right Front Corner Voltage: 13.6 V
Left Rear Corner Voltage: 13.6 V
Right Rear Corner Voltage: 13.6 V
LIN and Miscellaneous Configuration:
Alert on no Reply: Set
Alert On System Fault: Set
Alert On Search Timeout: Set
Auto Relock Time: 60 sec
Compass Mounting Angle: 0 Deg
Snow Plow Enable: Not set
Panic Enable: Set
Compass Mounting Orientation: Not set
Washer Fluid Level Voltage Threshold: 4.46 V
Fobik Safe Alerts Per Ignition Cycle: 32
UCONNECT Access Mirror Buttons Present: Set
RCM Present: Not set
Humidity Sensor Present: Set
Manual Trans Present: Not set
Smart Beam Present (AHBM): Not set
DC to DC Converter Present: Set
ASBM Present: Not set
VTA System Present: VTA
EOM Present: Not set
DC to DC Converter #2 Present: Not set
Illuminated Approach Interior Lighting Target Percent: 175 (87.50%)
Illuminated Approach Headlamp Target Percentage: 125 (62.5%)
Illuminated Approach Taillamp Target Percentage: 125 (62.5%)
Illuminated Approach Interior Lighting Ramp Up Time: 113 (2260 ms)
CRVMM Present: Set
IBS Configuration:
IBS Quiescence Current Limit: -250 mA
IBS Minimum Voltage Limit: 10.00 V
IBS Minimal Charge Limit: 125.00 A/H
CBC I/O Usage Configuration:
Connector F Pin 22: Analog Spare Input #1 Usage: Manual T-Case
Connector F Pin 5: Left Rear Fog Lamp/High Beam Shutter Usage: Left Rear Fog Lamp
Connector E Pin 39: Right Rear Fog Lamp/High Beam Shutter Usage: Right High Beam Shutter
Left High Beam Feed Usage: Left High Beam (0)
Right High Beam Feed: Right High Beam (0)
Front Driver Door Ajar Switch Signal Usage: Disabled
Connector F Pin 28: Front Passanger Door Ajar Switch Usage: Disabled
Connector F Pin 27: Left Rear Door Ajar Switch Signal Usage: Disabled
Connector F Pin 31: Right Sliding Door Ajar usage: Not defined
Spare LSD Relay #1 Usage: Snow Plow Low Beam Control
Spare LSD Relay #2 Usage: Not defined
Connector A Pin 11: Hood Ajar Switch Usage: 1K parallel resistor
Connector E Pin 21: IOD RELAY ON LSD: Snow Plow High Beam Control
IOD HSD Relay On Usage: Snow Plow Left Turn Lamp
IOD HSD Relay Off Usage: Reserved
Stop/Start Enable Switch Present: Not set
ITM Configuration:
Siren: Not set
Ultrasonics: Not set
Tilt: Not set
Cluster Configuration:
Fuel Tank Calibration, Full: 91%
Fuel Tank Calibration, Empty: 2%
Fuel Tank Calibration, LFW: 8%
Cluster Configuration 2:
Fuel Tank 2 Calibration, Full: 91%
Fuel Tank 2 Calibration, Empty: 2%
Fuel Tank 2 Calibration, LFW: 8%
2014 CBC I/O and Features Configuration:
Analog Spare Input #2: Not present
Analog Spare Input #3: Right B-Pillar Sliding Door Switch
Analog Spare Input #4: Driver Door Lock Switch
Analog Spare Input #5: Not present
Analog Spare Input #6: Not present
Truck Bed Lighting Feature: Not present
High Beam Lamps Open Circuit DTC Enable: Not set
Dedicated DRL Lamps Open Circuit DTC Enable: Set
License Lamp Open Circuit DTC Enable: Set
Reverse Lamps Open Circuit DTC Enable: Set
Stop Lamps Open Circuit DTC Enable: Not set
CHMSL Lamp Open Circuit DTC Enable: Not set
Front Park Lamps Open Circuit DTC Enable: Not set
Rear Park Lamps Open Circuit DTC Enable: Not set
Front Fog Lamps Open Circuit DTC Enable: Not set
Rear Fog Lamps Open Circuit DTC Enable: Not set
Baggage (Cargo) Lamp Output Disabled with vehicle: Not set
CHMSL Lamp Output Disable: Not set
IOD Relay Voltage Sense: Not set
Manual Door Locks Present: Not set
Rain Sensor Module #2 Present: Not set
Humidy Sensor Long Present: Set
Auto High Beam Module Location: CRVMM
License Lamp Disabled: Not set
Right Rear Turn Signal Usage: Right Rear Turn Signal
Left Rear Turn Signal Usage: LEFT REVERSE LAMP #2
Acceleration/Braking/Steering values:
Excess Lateral Acceleration Factor: Filter Off
Average Last Lateral Acceleration Values: No Averaging
Excess Longitudinal Acceleration Factor: Filter Off
Average Last Longitudinal Acceleration Values: No Averaging
Brake Smoothing Duration: Filter Off
Brake Smoothing Factor: Filter Off
Steering Smoothing Duration: Filter Off
Steering Smoothing Factor: Filter Off
Steering Smoothing Threshold: Filter Off
Brake Smoothing Threshold: Filter Off
Maximum Longitudinal Change: Filter Off
Maximum Lateral Change: Filter Off
Acceleration Threshold: Filter Off
Nose Dive Threshold: Filter Off
Nose Dive Factor: Filter Off
Radio Features Configuration:
Radio Speaker Open Circuit Disable (LF): Set
Radio Speaker Open Circuit Disable (RF): Set
Radio Speaker Open Circuit Disable (LR): Set
Radio Speaker Open Circuit Disable (RR): Set
ANC Calibration Parameter Data Set: Not defined
Defrost Mode and Heated Mirrors Present: Both
Auto Dimming Mirror Hard Button Present: Not set
Trailer Hitch Camera: Set
Programmed ECUs: Cabin Network:
RBSS Right Blind-Spot Sensor: Not set
LBSS Left Blind-Spot Sensor : Not set
BCM Interior Bus: Set
CSWM Comfort Seat Wheel Module: Set
HSM Heated Seat Module: Set
DDM Driver Door Module: Set
PDM Passenger Door Module: Set
DCM_RL Door Control Module Rear Left: Not set
DCM_RR Door Control Module Rear Right: Not set
HVAC Heating, Ventillation & Air Condition: Set
MSM Memory Seat Module: Not set
PLGM Power Liftgate Module: Not set
VTM Vehicle Tracking Module: Not set
PSDML Power Sliding Door Module Left: Not set
PSDMR Power Sliding Door Module Right: Not set
FSM Fold Stow Module: Not set
PTCM Power Top Control Module: Not set
RBC Regenerative Brake Controller: Not set
DTV Digital Television: Not set
Radio: Set
Clock: Not set
VSIM Vehicle System Interface Module: Not set
ITM Intrusion detection: Not set
AMP Audio Amplifier: Not set
ETM Entertainment Telematic Module: Set
HFM/CTM Hands Free Module/Convergence telematic: Not set
ICS Integrated Center Stack: Set
VES2 Second Row Screen: Not set
VES3 Last Row Screen: Not set
CRSM: Not set
HVAC_R Rear Heating, Ventillation & Air Condition control: Not set
CVPM Central vision processing module: Not set
Programmed ECUs: P/T Chassis Network:
ACC Adaptive Cruise Control: Not set
ADCM Active Damping Control Module: Not set
AHLM/AFLS Headlamp Leveling: Not set
ASCM Air Suspension Control Module: Not set
BCM (PT) Body Control Module: Set
DTCM Drive Train Control Module: Set
ECM/PCM Engine/Powertrain Control Module: Set
EPS Electric Power Steering: Set
ESM Electronic Shift Module: Set
ABS: Set
EPB Electronic Parking Brake Module: Not set
RFH Radio Frequency Hub: Set
IPC Instrument Panel Cluster: Set
ACC/DASM Adaptive Cruise Control: Not set
FDCM Final Drive Control Module: Not set
EPPM Electronic Pedestrian Protection Module: Not set
ORC Occupant Restraint Control: Set
PTS Parktronics: Set
RBT Driver: Not set
RBT Passenger: Not set
SCCM Steering Column Control Module: Set
ELSD Electronic Limited Slip Differential: Not set
TCM Transmission Control Module: Set
TPM Tyre Pressure Module: Not set
PASS (PT): Not set
AFLS Discharge lamps: Not set
ITBM Integrated Trailer Brake Module: Not set
OCM Occupant Classification Module: Set
FFCM Front Facing Camera Module: Not set
HCP Hybrid Control Processor: Not set
ANC Active Noise Cancelation: Set
Programmed ECUs: Hybrid LAN Network:
APM Accessory Power Module: Not set
TCM Transmission Control Module: Not set
BPCM Battery Pack Control Module: Not set
MCPA Motor Control Processor A: Not set
MCPB Motor Control Processor B: Not set
