Alfaobd Speedo help
JIMBODIO
Hi all. Hoping someone can shed some light on my issue. Have the latest update, I believe, of Alfaobd. Using a security bypass module. Went in to BCM and went to program tire size, did my thing. After doing that, my park sensors say unavailable and the electronic emergency braking isn’t working. Hoping someone can shed some light on this issue. TIA
vincentw56
That means your tire size is out of spec. There are many threads on it. You will need to set it to the closest spec. I don't know what those are so do a search to see if you can find a thread about it.
LiveWire
I have a pulsar tuner, when I adjust tire size park sensors are unavailable. According to Diablosports nobody in the industry has figured out how to get around that yet.
But you answered my question, i was wondering if the alfaobd would do it. I talked to one dealer, they said it was like $500.. But I dont think that guy knew what he was talking about.
JIMBODIO
I solved the park sensor issue with Alfa OBD. I am working with my Snap On guy to unlock the secure gateway through my scan tool. I have a park brake warming light and code that won’t go away.
