Alfaobd or Revel links?
redhawk
TX
Am I still need revel links for my truck ? Normal ride height mode is 1.2" taller after enable VehConfig 2-Off-Road Capable in alfaobd. It's also removed off-road 2 setting, same as ORG truck. My truck is 4x4 air suspension, non ORG .
Thanks in advance
Mketch
Thanks in advance
I think you can adjust the height of each corner down to the mm in alphaobd, seems like it takes more work and measurements so most prefer adjustable links. I want to do the reverse of what you did to my ORG so I have more adjustability. We’re you in normal mode when you made the switch?
redhawk
TX
36.6" front ground to center of fender before made change in alfaobd
