BritinMN
Hi!
My 'new to me' 2019 Limited has the (what appears to be common) air suspension 'lean',..... So I hooked up my Alfa OBD and EX USB cable to my Windows PC, just like I had done on my last Ram, and decided I would just take a quick peek at some live data to see what the system thought were the various values for the suspension....
Oh boy - was that a mistake!
I was able to connect to the suspension module, checked for faults (there were none), so I moved on to the Active Diagnostic tab... found a test that said 'Component Air Mass/Pressure/Ride Height Readings' ...... aha!! Just what I need I thought.. and it's only going to 'read' the values! I 'started' the task..... it just sat there doing nothing... after a few minutes I hit stop.
This gave me the in the dash display 'Air suspension inactive' message and the lights not he suspension height adjustment were all flashing. Tried unplugging the battery overnight etc. .. nope still there this morning.
This morning I was able to find the suspension had gone into 'plant' mode, so I used the 'get out of In-Plant mode' diagnostic - that got the suspension gods back on my side, the inactive message went away and suspension flashing lights stopped...... But.....
It seems that all kinds of configuration settings have changed....... It's like it has forgotten it is a Limited!! Examples
In dash screen still has the 'Limited' splash screen when you power up... but when you get the data up on the screen the fonts are different i.e. not the weird 'Limited' font, but back to what I was used to seeing in my Laramie ....
The Radio screen (it is a limited so it has the big one) has lost/reconfigured a bunch of things.... Passenger side seat heating/ventilation has disappeared. In 'Settings' the Suspension button has disappeared.... no longer any setting for the powered running boards etc......a bunch of the default apps have changed/gone.
Of course I hadn't created a backup file of ANYTHING as it was the first time I have used it on this truck and was not looking to do anything other than LOOK at values....... Any experts on here seen anything like this before? Any thoughts/Ideas on how to get everything back to the truck knowing it is a LIMITED and has all these belts and whistles??
I totally get managing to mess stuff up if I was in there actively changing parameters..... but boy, this seemingly 'innocent' task of trying to look at values has scared the crap out of me!!
Any suggestions/insights would be GREATLY appreciated!!!!!!!
