Air suspension sensor plug
ZachT
Hey forum -
I've got a 2019 Limited with air suspension. I installed 20x10, -19 offset wheels with 305/55/20 and am getting slight rubbing. I'd like to get rid of it. I already have Revel Links but also purchased a set of Rough Country brackets.
My problem is, I cannot figure out how to get the sensor unplugged from the wiring harness. I really don't want to break it. Anyone know the trick to getting it un-plugged?
Zach
kapinallinen2
5thGenRams Supporter
Southern Maryland.
Hey forum -
Zach
AFAIK you need to unlock the connector by sliding out the locking tab with red on it.
ZachT
That's what I tried and how the instruction say to do it, but man is it stuck. I really don't want to have to de-pin it to replace the connector if I break it.
Zach
kapinallinen2
Southern Maryland.
Zach
It is tight. Push down on it with a flat bladed screw driver, after that, you still need to release the connector retaining clip.
ZachT
Thanks. The image helps reinforce I was doing it right, just being to easy on it. I'll go at it again. If it breaks, it breaks.
Zach
ZachT
I know it's been a minute since I posted this. Thought I would follow up. I got the connectors apart. The grit was really sticking them up.
Turns out the Rough Country brackets combined with the aftermarket links is not a good move. The ride was extremely rough and it seemed to confuse the system. It would randomly switch from Normal to Aero to Offroad 1 when starting the truck.
I pulled the aftermarket links and re-intalled the stock links and ride is great. No rubbing either. This is the way.
Zach
