Air suspension lift spacer questions?
aimlowrobin
I have read a lot of info on this page and it has been very helpful. I have owned several RAMs, but new to air ride. I have a limited with AirLinks installed. I see a lot of people using Daystar front spacers also. Is there a reason that has become the brand of choice?
Also, is there any option for a similar rear spacer? I prefer to keep the rake and am considering maxing the lift I can get with links, spacers, and upgraded control arms. Mostly because BDS can't get their crap together on a 2021 lift kit. The pic attached is with links, normal setting and 34s. Ride is fine as is, in normal. Just looking for more height.
I bought the Daystars because they'd been proven to fit, affordable and could be bought as a package with links (front and back). Not sure about rear spacers. I raised the rear using the links enough for ~1" of rake. I didn't want to max out the front links with the spacer because as I undestand it; the spacer allows you to have the 2" lift without overinflating the bags and maintain all height levels (Entry -> OR2). Maxing out the links with the spacers I suspect would affect ride quality (overinflated bags)..
Understand why the spacers help. Just neber see anyone do the back as well.
