Cdcrawford25
I noticed today while highway driving that my air suspension never lowered to aero like it normally does. Anyone else experience this?
Yes it is still set to use Aero in the settings. It also did not reset itself to Normal after I manually set to Aero as it typically does once I am no longer at highway speeds. I am going to continue to monitor the situation.Is the aero mode still selected in settings? Weird things happen sometimes.
I also left it set to aero in settings as it goes threw the motions that was in auto when I get on highway over 66 mph....some times i run up 67 just a short time so aero turns on so I can watch it work.Yes it is still set to use Aero in the settings. It also did not reset itself to Normal after I manually set to Aero as it typically does once I am no longer at highway speeds. I am going to continue to monitor the situation.
I brought the truck to the dealer today and now my system is working properly!
They told me they didn't reset anything and couldn't replicate the problem. Sure enough I took it for a test drive with the technician and the air suspension performed flawlessly.
It didn't work properly for 4 weeks. I bring it today and it is working fine. Either it was a miracle or they did something but won't tell me LOL
What are the chances???? Hopefully it will continue to work as advertised now
As a side note, I noticed a spot in between two cars while I was there and got a chance to try the auto parallel parking feature. The spot looked kind of tight to me and it had a chain link fence on the inside but it parked the truck right in between the two cars and left me about 18 inches inside the fence! Love it
Man, you should like a lawyer lolJust a friendly warning, document everything when you visit service for air ride issues and NEVER leave without the documented service record. They have to document everything, including doing "nothing". If you don't keep track, it can be an expensive learning experience.
Not trying to fearmonger, just sharing advice based on experience with air ride issues.
Touche, bro, touche!Man, you should like a lawyer lol
I have the paperwork!Just a friendly warning, document everything when you visit service for air ride issues and NEVER leave without the documented service record. They have to document everything, including doing "nothing". If you don't keep track, it can be an expensive learning experience.
