Rototerrier
- Dec 7, 2018
Some of you may have seen some of my other posts having to do with my botched paint job and buy back. For the buy back, I dropped the eTorque and added Air Suspension. So far, absolutely loving my decision to drop the eTorque, but the Air Suspension is a little iffy. Since my previous ride had coils, and I put over 3k miles on it, I have a very good basis for comparison. There's quite a big difference.
The issue I am having is that the truck just feels wobbly. Hard to explain, but when the road surface is uneven or has little bumps that should just be soaked up by the suspension, it seems to result in a wobbly feeling. I literally feel like a bobble head doll. The movement is over exagerated and it feels like you have to force your head to stay still. It feels unnatural. My previous truck just had the coils and it rode amazing. Very planted and very smooth. No issues like this at all. But, I also tow a lot and I really like the auto leveling feature of the Air. I'm definitely not regretting my decision in that regard, I am hugely benefiting from this and wouldn't go so far as to say I would want to go back to coils...yet. I just need to figure this one issue out and I'll be good to go.
I've just ordered the Hellwig adjustable rear sway bar to see if that will tighten things up. This morning, I'm going to go out and start experimenting with tire pressures and see if that helps as well. Any suggestions on pressures? Would higher or lower pressures offer a more planted feel? Or is it all just trial and error?
Unlike others, that seem to be complaining that their Air is too stiff and rides like a dump truck, mine just feels loose. The firmness seems fine, just isn't planted and the entire body just seems to wobble and move more than it should. I know this probably isn't the issue, but the feeling I get would be as if the suspension wasn't fully bolted to the frame. It soaks up the bumps straight on, as you'd expect. But, anything that causes sway is way over exaggerated and in a way that would make you think the whole frame is moving around.
This forum has been a great help to me so far, so I thought I'd reach out again and see if anyone out there can offer up some much appreciated advice. Thanks in advance!
