I also thought about this! Adjustable air ride but if you go over the speed threshold it lowers the truck to aero mode, what fun is that?Is there a way to turn off the computer from automatically raising or lowering the truck when you hit the speed threshold? Is it possible to drive over 5-10mph in entry/exit or off-road 2 mode? Thanks.
Is it difficult to use? Ididin't seem RAM listed as a vehicle or unit supported. It looks like it's mostly Fiat's and Alfa's.AlphaOBD is an app for your PC or phone you can use to program most of the computer options of FCA vehicles. If you want to tinker or customize anything and do 95% of what a dealer can do, sometimes even more than a dealer can do, it is what you want.
Power cycle is turn it off and back on again.
That does look easy. When I click the link you provided to their site, I don't see Ram listed under "supported cars" or "supported units". I also have an iPhone, not an Android. Perhaps that's why I"m having problems. You have to buy the key or module to plug it in under the dash, then you can connect it to your phone, right? I appreciate your help. This is definitely a bit confusing to me.It's easy. Pick Dodge/Ram. Pick Suspension. Pick ASCM
Hit connect and then Hit the hood open icon.
Set the height you want. Then select disable level control.
View attachment 93914View attachment 93915
a elm237 adaptor ( https://www.amazon.com/gp/product/B01HXGX8V6 ). I have both a obdlink mx and a knock off elm237 and they are the same. the obdlink is slightly faster and in no way is worth the premium.
for ios, you need a wifi version. https://www.amazon.com/dp/B077F8F6TB/ I don't think alphaodb will work with ios either. use the wifi version and PC I guess?
Thank you for all of your help. Do you have a link where I can read about this? I'm not sure I follow what I need and how it will all work. So since I have an ios I need, https://www.amazon.com/dp/B077F8F6TB/ is that right? Which is the ios version knockoff of the obdlink mx? Then I need to download what app? I am not sure what you meant by, "use the wifi versiona nd PC I guess" I have a macbook pro, can I even do this kind of thing on that type of laptop? Thanks again for your help. I hope you don't regret responding to me lol.
I am a Mac/iOS guy as well with a ram limited 2021.Thank you for all of your help. Do you have a link where I can read about this? I'm not sure I follow what I need and how it will all work. So since I have an ios I need, https://www.amazon.com/dp/B077F8F6TB/ is that right? Which is the ios version knockoff of the obdlink mx? Then I need to download what app? I am not sure what you meant by, "use the wifi versiona nd PC I guess" I have a macbook pro, can I even do this kind of thing on that type of laptop? Thanks again for your help. I hope you don't regret responding to me lol.
You probably need to rerun the calibration for each height. Don't know, never done it aside from "fixing" the driver front being 2" lower than the rest of the truckFollowing. My check air suspension light comes on all the time now after daystar spacer and revel links (only happened after last dealer service, not sure if they did something..)
How do you do that?You probably need to rerun the calibration for each height. Don't know, never done it aside from "fixing" the driver front being 2" lower than the rest of the truck
You’re the man! Thank you! My 33x12.5x22 only rubbed in aero. Great to eliminate that
I also am “all MAC/iOS”.I am a Mac/iOS guy as well with a ram limited 2021.
Did you figure this out by chance? I’m trying to figure out how to stay on off-road 1 so I can run some 35 inch tires all the time.
Thanks!
