CaptainSumTingWong
- Dec 30, 2020
I have a 21 limited I just put daystar spacers and revel links on, and the problem that I’m seeing here is that the UCA at full droop contacts the shock body. Does anybody make an UCA that would give more clearance on the shock body and also clears the ride height sensor and comes with the 8mm ball to attach the links?
The only other option I’ve seen with the connector for the links is the mopar UCA but it does not give any additional clearance for the shock body and sensors.
