Rickymetcalf
- Jan 22, 2021
Do you think the UCA would work with my 2.5 level?
The BDS part number for the DT UCAs is the same part number BDS uses in the DS trucks..The front suspension was revised. That is the reason why zone does not recommend using the old-style control arms. Suspension droop is the biggest problem. Most people don’t take these trucks off-road getting a wheel or wheels off the ground putting the additional stress maxing out cv angle and ball joint angle.
I can’t remember where I read specifically about the UCA difference but this article explains our suspension very well.
2020 Ram 1500 Suspension Deep Dive | Coil-spring rear suspension explained - Autoblog
Engineer Dan Edmunds takes a deep dive under the Ram 1500 to explain its trademark coil-spring rear suspension.www.autoblog.com
I thought the BDS control arms were around $350. I was confusing that with the rough country upper arms.
Now here’s the funny thing... take a look at the upper control arms from BDS.
Shop by Products
SUSPENSION SYSTEMS LEVELING KITS LIFT KITS 0 to 3.5" LIFT KITS 4 to 5.5" LIFT KITS 6 to 7.5" LIFT KITS 8 to 10" LIFT KITS SUSPENSION UPGRADES CONTROL ARMS 4-LINK ARMS RADIUS ARMS UPPER CONTROL ARMS SPRINGS ADD-A-LEAF BUSHING & HARDWARE COIL SPRING SPACERS COIL SPRINGS LEAF SPRINGS LEAF SPRING...bds-suspension.com
They are listed as fitting a 2006 through 2020 ram 1500. BDS and zone are the same company. Now obviously these are two different products and the BDS Arms add 1.4° of positive caster. That will move the wheel forward and give more clearance for larger tires. It is not an OEM spec arm therefore I would have to assume logically that’s why it would fit 2006 through 2020 trucks.... interesting.
Below is what the website states:Do you think the UCA would work with my 2.5 level?
BDS website list UCA from 06-21Yes you’ll be at 3.5 inches and yes your CV angles will be really bad. That much lift is not recommended for off-road use. The upper control arms from the fourth gen ram will fit but they are not the same geometry. Why not upgrade to the BDS tubular control arms for the 2020. Priced very reasonably and are actually designed for the fifth gen
bds-suspension.com
$772 for UCAs is reasonably priced?BDS website list UCA from 06-21
Shop by Products
Did you adjust or check your alignment? I have a 2021 and installed the 2” motofab spacers and looking (as others) into UCA . I never off road .To clarify I have the mopar 2" lift with ORP springs in front netting approx 3" of lift in front and 2" in rear. The extra inch of lift in the front comes from the ORP spring. I didn't modify the UCA at all even though they were for a 4th gen but they fit like a glove.
