aftermarket tire/wheel swap for Gen 5 Laramie
jrw921
Texas
want to change out the 20x9 OEM wheel/tire setup and need to know if anyone has information on what sizes/widths/offsets, etc will work. Stock height, no lift or level.
I want a wider tire and would like to drop below the standard 19mm offset to push the wheels out a little. With no suspension modifications, how wide will work without rubbing?
Look at customoffsets.com they have a gallery with a bunch of our trucks showing different sizes and suspension heights.
There is over 2 years of information on the 5th Gen wheel tire swaps on this forum. Ypu've come to the right place. Search is your friend.
I second the custom offset deal. Between them and searching on this forum that’s how I gathered enough info to know I could go with a 12 wide tire on a 10 inch wide rim and not have any rubbing without a lift or level.
